What Brand & How Much ATF needed?
Old May 19, 2003 | 12:39 AM
teejnut's Avatar
I was wondering how much ATF is needed when installing a VB? Also, what brand is recommended?
I'm thinking about going with the Redline D4 ATF. So far the only two places that I know that have them are www.myoilshop.com and www.summitracing.com does anyone know of any other place?
Any recommendations or advise is appreciated. Thanks!
TJ
Old May 19, 2003 | 03:38 AM
Kanaka's Avatar
i would try to stick to the oem stuff from nissan. only thing is it's hard to find a dealer who sells it. they usually only use it for their service departments. i think it's called matic-d
Old May 19, 2003 | 05:29 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Actually, synthetic fluids are much better than the "oem stuff." Some good brands are Royal Purple synth ATF, and Amsoil synth. ATF... Only thing is, they're quite expensive, and run up to 8-9 bucks a quart.
If you're dropping the vb, you need about 6 quarts to replenish what's been lost... You should go ahead and pick up 7 though, especially since you'll probably be throwing a tranny cooler on while you're at it.
Old May 19, 2003 | 10:45 PM
teejnut's Avatar
Thanks! Exactly what I was looking for!
Old May 19, 2003 | 11:27 PM
(_8*(l)Homer's Avatar
How about Mobil 1 synthetic ATF? Is that any good?
Old May 21, 2003 | 05:48 AM
iwannabmw's Avatar
Yes, it's better than conventional ATF's. If you're making the jump to synthetic, I would recommend going with either Amsoil or Redline though.
Old May 21, 2003 | 10:19 PM
95seMax's Avatar
i taught u needed 12 qrts to refill ur tranny if you do a complete tranny flush?
Old May 22, 2003 | 03:12 PM
iwannabmw's Avatar
Pretty much. The total capacity of the tranny is 10 qts, so 12 ensures a complete flush.
Old May 22, 2003 | 10:17 PM
turbomax97's Avatar
12 is right, but as the ORIGINAL POST says... he's doing a vb install, not a tranny flush.
Old Oct 29, 2003 | 09:13 AM
Broaner's Avatar
2060lbs and falling...
So what is all this 4.5 qts that I hear. If I need 12 qts of redline im gonna be broke. Also, what kind of redline? ATF-##?
Old Oct 29, 2003 | 12:15 PM
turbomax97's Avatar
the 4.5 qts is what u get out if u just pull the plug and drain the fluid. There's still another 8.5 quarts in the torque convertor and the tranny casing.
smplyamzng
Dec 13, 2015 01:19 PM
mclasser
Aug 23, 2015 09:32 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
TonyJr
Aug 20, 2015 12:14 AM
