Very loud sound after Eibach Spring install
Hey everybody I got my Eibachs installed a couple weeks ago and ever since when I turn the wheel all the way to the left or all the way to the right I get a very loud kind of crunching sound, all I know is it is very lound, somtimes I get it going over bumps as well, also if it means anything I'm also starting to get squeeks and other noises when going over bumps.
- Steve
- Steve
The crunching is your CV Boot is in need of replacement, where as the squeeks can be fixed like so:
http://www.vqpower.com/v2/modules.ph...howpage&pid=11
Originally posted by FLAVOR247
A crunching noise may actually be your cv joint, normally its a knocking noise. Look under your car and see if the boots torn.
- Steve
Originally posted by dmBK
NO!!!!!!!!!!!
NO!!!!!!!!!!!
So back to my other question, this sound I would be getting if my CV joint was bad is it a rather loud sound or a quiet sound?
- Steve
Originally posted by idolsword
I'm sorry sir, I can tell this was a stupid question.
- Steve
- Steve
Like dave blackburn stated, most likely its the outer. Look under the car, if the joints is bad the boot will be ripped,or torn. Which causes it to loose grease and allow dust in making the joint go bad.
if u havnt got a bunch of lil rocks and pebbles in there already..then go replace thh cv boot(40-60 bucks at local shop).. if it is clanking that badly u might haev to replace the whole joint..those lil pebbles can waer it down over time and you'll be in trouble if that happens.
cv joint is inside the cv boot. boot protect the joint from dirt, rust, sand, rocks ect. there is buncho grease inside the boot to keep the joint lubed. when boot break, grease leaks.its nasty.take off your wheel and you cant miss it..if in fact your boots are blown, you will see it, or see grease everywhere.
dank4us
04-01-2019 04:06 PM
95Maxi
35
09-02-2015 10:37 AM
