Digital clock
Old May 21, 2003 | 07:36 AM
H.N.I.C.95's Avatar
Digital clock
What could cause my clock to go out?
Old May 21, 2003 | 07:37 AM
Flava_24/7's Avatar
Boosted Panda
Re: Digital clock
I have an extra one if you need it.
Old May 21, 2003 | 07:43 AM
cam_honestiam's Avatar
Check the dimmer switch first. Then, check for any blown fuses. If that does not solve the problem, take out your fan vents (gently tug out and up) and check the plug to the clock display to make sure it is snug and receiving power.
Old May 21, 2003 | 03:24 PM
taeMAX97's Avatar
my clocks been acting up on me too. time just resets by itself... any ideas??
Tae
Old May 21, 2003 | 05:00 PM
max_speed97's Avatar
my clock also is messed up. mine comes on at times and shuts off...but it is mostly off. when i was at dealer once i asked if they can look at it and they said all connections were ok and did not know what was wrong. they said maybe it burned out or somehting...i dont think they really knew...and they said to get a new clock...
Old May 21, 2003 | 05:10 PM
maxnomo's Avatar
Mine resets constantly and turns off completely intermitently.
Old May 21, 2003 | 06:19 PM
JMAXIMA's Avatar
mine too... i even took it down the the circuit board and everything looked ok. i'm going to check the connecting pins this weekend to see if any are loose. its got to be a bad connection b/c if i tap on the area above it, it typically comes back on for a while.
Old May 22, 2003 | 09:22 AM
Bad connections are likely. With vibration, the solder can come loose from the circuit board. It is not hard to take the clock apart. I would use a continuity tester at one contact where the wire plug attaches and test the contact at the circuit board. Wiggle it a bit and see if the contact is constant or broken. A hairline crack could cause it to lose power for a split second, long enough to reset the clock. Tapping a clock that is off would work because you could jostle the crack. Once you find the crack, add a bit of solder and test again. If there is no crack and you are sure of it, check the wiring by plugging the clock back in and bending the wires at certain locations. Simulate any bumbs with the clock plugged in and you should be able to narrow it down. As a last resort, find a clock at the junkyard.
Old May 22, 2003 | 05:24 PM
Max97SE's Avatar
Cam_honestiam is correct. My clock started to intermittently go out or reset to 1:00 when I would start my car. I resoldered the 4 solder joints of the 4 prong connector with good results but eventually another joint failed somewhere else so I opted to buy a vent / clock assembly from a Infiniti I30 (same clock) off eBay for $20 with local pickup. Check out the link Cart Parts link below and search for a used clock. I found one used part dealer that would sell on for $35 shipped with a 90 day warranty. http://www.car-part.com/ Some are pretty quick with email responses. Here is the message that I received on 04/29...
WE HAVE CLOCK FOR $35 DELIVERED TO NY WITH 90 DAY WARRANTY. To order or questions please feel free to contact me at 800.336.2231.
_
Best regards,
Jason Carroll
Internet Sales
_
AA Auto
8125 Highway 161
North Little Rock, Arkansas_ 72117
United States
http://www.aaforeign.com
shilov
Feb 19, 2024 09:40 PM
viperboy
Sep 27, 2015 07:05 PM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
