Odd question for those with larger than stock wheels
I just put on some 2002SE wheels on my 98 max. I love the way it looks and it rides fine, the only thing that seems odd (not bad I guess) is that I feel the road imperfections more. To some extent, I knew I would, my problem is that if there are ruts in the road, my car now seems to REALLY want to get in the ruts. My steering wheel will pull to whatever side when the pavement is uneven. It just seems more noticable now that the bigger wheels are on but I don't know why.
Does anyone else have this? Is it just normal and I'm paranoid?
Originally posted by waveridr85
get used to it,
high tire presure
low profiles
stiffer struts
stiffer springs
will all make you feel the road imperfections more
get used to it,
high tire presure
low profiles
stiffer struts
stiffer springs
unless it's pulling hard to one way or the other, it sounds normal. if you think you might need an alignment then you should go get it checked out before your tires begin to wear unevenly. i feel more than my share of bumps and grooves in the road....but you get used to it.
Re: Odd question for those with larger than stock wheels
GMT
are your new tires bigger than your old tires? wider and directional tires will track the road more than skinnier tires. with my 255's i follow every groove in the road, but with the stock tires it flies through everything.
Not only that, but your car probably runs slower, too. That's the price you pay for up sizing your wheels. It'll handle cornering better, but your 0-60 and 1/4 time will increase.
I think 18s look fantastic on the 4th and 5th gen, but I just dont want to pay the performance penalty on them.
DW
DW
get used to it,
high tire presure
low profiles
stiffer struts
stiffer springs
get used to it,
high tire presure
low profiles
stiffer struts
stiffer springs
DW
DW
And yes, I noticed the slow take off but I can deal with it for the looks, I'll put my 16's back on for the track. I ran a 16.02 totally stock with the heavy 17" rims so I'm hoping to break 15's with my y-pipe and 16's back on.
Cant_Get_Ryte
08-28-2015 06:41 AM
MaximaDrvr
08-19-2015 08:20 PM
