how to reset deployed airbag module?
Is there away to reset a module of a maxima whose airbags were deployed. it had side airbags too but they didnt deploy. thank you
-Sal
ps i did tried the other procedure the door switch thingie .. but it didnt work for me
-Sal
Did you replace the sensors that were tripped?
Once a sensor is tripped it must be replaced. The module will not reset until the system is all clear. Just like an alarm will not arm until all the doors and windows are closed.
Just a word of advice:
Your really should let a certified SRS technician repair and reset your Air Bag System. Most Body Shops have at least one guy certified to work on SRS systems. You can also visit your local Nissan Dealer.
The airbag control unit module has a built-in shock sensor. You could be looking at replacing the module, since you have triggered the actual module itself. It's for your own good, otherwise you might as well remove your airbag system completely. Looks like you've got to plop the dough. Sorry.
Do what njmaxseltd said, make a visit to the dealer or someone, and have them diagnose the issue.
knight_yyz
Nov 1, 2015 01:34 PM
