help, my engine is knocking
Old May 23, 2003 | 12:28 AM
Dev's Avatar
Dev
ok i had the problem this past winter, but it went away when i got new spark plugs (copper ngk) but it has started again recently.
it happens only under hard acceleration, which i stopped doing for the time being. i cleaned my TB last month, and use 94 octane gas all the time. i just purchased amsoil fuel injection cleaner, and will use it once i go to the gas station.
but does anyone else know what the problem might be?
i don't have a CEL, so im guessing its not an ignition coil.
but i haven't checked for hidden codes.
Old May 23, 2003 | 01:24 AM
Nismo's Avatar
are your coppers all gapped correctly?
Old May 23, 2003 | 01:28 PM
Dev's Avatar
Dev
they're all gapped to .042 which is right in the middle of the specified range.
Old May 23, 2003 | 02:21 PM
hokiemax's Avatar
hey wait a minute.. you have a 99... I think it might be your coils. my bro's 2k 5spd knocks all the time. I hvaent really done this research in the 5th gen forum, but he says the knocking is due to bad coils and that every 5th gen owners know that.. you might want to get a set of new coils and try them on or you can always get an AFC and tune your car out. we were gonna get an AFC for my brother but he says he found out the problem was with the coils. He gets no CEL light either.
Old May 23, 2003 | 02:24 PM
Dev's Avatar
Dev
hmm...crap...coils are expensive
the thing is...it was doing it before...and then stopped for a few months, i even went to the track and it was fine.
and all of a sudden its messed up again.
how did he find out which coil to replace?
my car only has 35k miles on it
Old May 23, 2003 | 04:20 PM
bobjohnson's Avatar
Blazin......
knocking is normal. i bet its not even knocking its just the timing chain rattling , yes it sounds that bad. mines a 95 auto w/ about 136,000 miles on it and its made a knocking , ticking sound the past 50,000 ive owned it. to fix it youll need the tension_plunger kit.good luck
Old May 26, 2003 | 10:12 PM
FLO_BOY's Avatar
what's this? please describe
DEV -- my answer to everything -- check the MAFS -- specifically, the wiring...
FLO_BOY
Old May 28, 2003 | 11:54 AM
astil's Avatar
good questions...How do you find what coil is defective or weak ? my 99 GXE 5 sp is acting up a litle between 1000 -1500 rpm .No light is on ...
Old May 28, 2003 | 11:58 AM
FLO_BOY's Avatar
knocking is normal.
I dunno about THAT statement...
As for figuring out what coil is bad...a couple things you can try:
1) unplug one coil and listen to the engine...if the RPMs drop, then
the coil is OK...if nothing happens, then the coil is defective.
When you do this one, you WILL get a CEL.
2) listen to each cylinder with a stethoscope (or, rubber tubing)
and hear for anything different.
This one is a little more difficult to determine what's what...
ASTIL -- can you further define your issue?
I know that there is a "dead spot" in the RPM range...don't remember exactly.
hope this helps,
FLO_BOY
Old May 28, 2003 | 01:49 PM
Canuck's Avatar
I just replace my coils for a misfire problem on my 99. The car only had 42000 miles on it
Old May 28, 2003 | 02:10 PM
maxspeed96CT's Avatar
The original VQ...
my motor knocks/ticks , a mechanic told me its prob my injectors, is this possible? I also have a bad front 02 sesor code, could this have anything to do with it?
Old May 28, 2003 | 02:13 PM
FLO_BOY's Avatar
could be injectors...
could be lifters...
bad O2 sensor is not the issue...the sensor sits in an exhaust
pipe, so, the combustion has already taken place...
FLO_BOY
Old May 28, 2003 | 03:20 PM
MaximaMoJo's Avatar
Dev, Your problem is not the coils! The knock probably sounds like a ball bearing rattling in a can, if this is the case it is detonation or spark knock. There are many causes of spark knocks including the build-up of carbon deposits, too lean of air fuel ratio, too high of a combustion for the octane grade, and the list goes on. Look up spark knock on Google or another internet search engine for more information. The reason I think it is spark knock is that you stated that it only happens under hard acceleration and that you had it and then it went away. This is my best guess!
ballerchris510
Sep 23, 2015 08:46 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
