Budget Y Installed Help!!
Old May 23, 2003 | 05:15 PM
ChristheNite
After more than a 6 hour battle with my old y-pipe I finally was able to get my new Budget Y in place. I hoped in the car after an oil change and went for a quick ride. I reset the ECU (moved the screw from left to right twice) and I'm not really feeling all the NEW power. Where should I be feeling the new horses and how long does the ECU take to recognize and work with the new Y? Sorry if this has already been asked...I admit it, I'm a NEWB.
Old May 23, 2003 | 05:49 PM
BlackCat's Avatar
RIP '98 Maxima SE
Don't worry. Its been mentioned that it will take a few days for the ECU to adjust itself to the change. I felt mine almost immediately based on the butt-ometer.
Old May 23, 2003 | 06:01 PM
99Maxima5sp's Avatar
I felt a substantial amount of power when i installed it, but its seemed to fizzle out, maybe im just used to it, but as you can see, my 1/4 times absolutely suck!!
Maybe with my custom B-pipe and new rear exhuast going on later this summer as well as these sticky as hell Yoko AVS ES100 tires, i can knock it down a few tenths..
Eric
Old May 23, 2003 | 06:03 PM
CaLSoNiC
From what Ive heard here, autos get less of a "butt-dyno" feel than a 5-speed.
Are you auto?
Or, have you taken it to redline, cuz I think its somewhere up there, but im not sure.
Old May 23, 2003 | 06:24 PM
ChristheNite
I'm a 1996 SE 5 Speed. I have a Stillen Cone Intake and the Budget Y. I dont know where i should be feeling the power - and apparently i lost my Butt Dyno - any suggestions on what that is or where i can find one...
Old May 23, 2003 | 08:07 PM
Dev's Avatar
Dev
Are you auto?
i disagree with that
i'd think it would be much easier to notice on an auto, because there is less driver influence. like i can shift hard and soft making it FEEL faster or slower...etc.
auto...you just floor it and know what it feels like...and it will feel different when you stick a performance mod on it.
as for the ypipe, i didn't feel gains immeidiately, and i didn't feel much at anytime actually. i went to the track before/after the ypipe, and i ran 0.2 seconds better, however i was launching much better this time, which is supposed to account for 0.2 seconds. and my trap speeds didn't increase
Old May 23, 2003 | 08:21 PM
maxspeed96CT's Avatar
The original VQ...
hit the highway and you will notice a big dierance
Old May 23, 2003 | 08:51 PM
StygianMax's Avatar
Look here and compare the two curves. One is pre-Budget-Y the other is post-Budget-Y. You see the hp gain isn't really prominent until 4500+ rpm.
Dyno plots are for '95 SE M/T.
Old May 23, 2003 | 08:58 PM
Flava_24/7's Avatar
Boosted Panda
I didnt really notice a big gain at first,but give it a couple of days. You will definatly feel it. It will start picking up right around 4k and keep going like StygianMax stated.
Old May 23, 2003 | 09:03 PM
joew's Avatar
That means it would be stupid to get a y-pipe for those with auto trans, right?
Old May 23, 2003 | 09:09 PM
ch13f's Avatar
wtf? It adds FWHP after 4500rpm, if you go WOT the car will shift at 6700rpm (or something close to that, I forget exactly)... It definatly wouldn't be stupid
Old May 23, 2003 | 09:11 PM
StygianMax's Avatar
I think you would still see the gains since M/T and A/T both have identically designed oem y-pipes (Cali spec might be the exception) with the restrictive pre-cats. I don't know for sure whether the difference would be the same or not. I'm just guessing here, but I can't think of a reason why the gains won't be similar to an M/T. Maybe someone with an A/T with dyno curves can comment with real data.
Old May 23, 2003 | 09:19 PM
igordlu's Avatar
I disagree a 4th gen automatic maxima with a shift kit "supposedly" shifts faster then a 5-speed
Old May 23, 2003 | 09:49 PM
ChristheNite
......ok ok
So i should be feeling the power MORE after 4500 RPM and it takes a little while to break in - everybody says it takes a few DAYS but does anyone have any idea how many MILES before I feel it? Thanks
Old May 23, 2003 | 10:09 PM
BadKarma99-4spd's Avatar
on the auto you will notice huge torque steer at 4k rpms. the first time i drove mine the wheel nearly yanked out of my hands.
i agree with the statement about the 5spd and auto, in the auto you just go wot and manually shift, so your shifts are virtually the same every time, there is no letting out the clutch softly or dropping it like in the 5spd where you can control your shifts.
Old May 26, 2003 | 08:48 PM
joew's Avatar
How can you push the rpm to 4k on DRIVE gear with an auto trans?
Old May 26, 2003 | 09:02 PM
ivelweyz
I feel the difference at aroun 3000 or 3500 rpm. Thing is I barely ever go past 2500 rpm it's kinda useless, until those pesky ricers rev at me at the lights. Then it really comes in handy. After about 4500 rpm, when the intake and y pipe seem to be the loudest, people just back off immediately...
Old May 26, 2003 | 09:03 PM
WhiteMax96's Avatar
I have mine since a month and half and i can say that you will feel the full power of the y pipe like 5 days after installing it. You will feel it!
Excalibur23
Oct 13, 2015 04:33 PM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
