How much HP loss with bad spark plugs?
Old May 26, 2003 | 10:03 PM
98maxsel's Avatar
When I got back car back from the mech. He told me 3 of my spark plugs were bad. It was discolored. This is due to me using nitrous without getting 1 step colder plugs. But my ? is how much performance am I losing? I heard people getting copper instead of platium plugs for nitrous right? Isn't copper plugs a lot cheaper anyway?
Old May 26, 2003 | 10:46 PM
Dave B's Avatar
Not DAVEB the parts guy
You're running nitrous without colder plugs Definately get a set of the NGK copper one step colder plugs. How much performance are you loosing? Depends on how bad your plugs were. I'd be more concerned about why they were discolored instead of how much power you're loosing. Just by looking at the plug you'll be able to tell a lot about what's going on in the motor.
Dave
Old May 27, 2003 | 08:32 AM
98maxsel's Avatar
cool thanks. how can you tell whats going on by the color?
Old May 27, 2003 | 09:05 AM
Jime's Avatar
http://www.eric-gorr.com/techarticles/sparkplugs.html
Here is one site but there are lots of others just do a search about reading plugs.
You are lucky if you ran spray with stock heat range platinum plugs.
I run two steps colder gapped at .035. The pressure from nitrous will blow out the flame from a platinum plug and for the same reason you gap them closer. Each step colder also reduces head temp by somewhere around 80 def F, don't mess around you are playing with fire.
Even for my 35 shot I run the same plugs.
Old May 27, 2003 | 09:50 AM
98maxsel's Avatar
thanks jim,
if I run 1 step colder, how much should I gap them?
Old May 27, 2003 | 10:29 AM
Jime's Avatar
Originally posted by 98maxsel
thanks jim,
How big a shot are you running? If 50 or below then I would gap around .040 if higher go .035".
mvm062
Nov 30, 2020 09:00 AM
knight_yyz
Nov 6, 2015 02:34 PM
JoshG
51
Sep 21, 2015 10:41 PM
chernandez1278
Sep 16, 2015 01:18 PM
