skyline headlights 95-99 maxima
Old May 26, 2003 | 10:41 PM
hairris's Avatar
Question: Will a pair of JDM R32 Projector headlights(j-spec) fit on a 95-99 maxima?(with little or no modification)
I have a friend who can get a pair of these used headlights for a cheap price. The man who he is buying directly from japan from says that they will bolt on the maxima without modification. I want to believe the man but if this was the case I can't see why everyone doesn't have a pair? Either way I just want to know if it is worth the buy and will I be able to have a new set of headlights?
Hairris
I don't have a picture? sorry?
Old May 26, 2003 | 10:47 PM
AuToMaX_95's Avatar
Not a direct bolt on. Some modfication is needed. NO body work though besides the bracet that hold th fender need to be shave off a bit. To get the corner light to fit flus.
How to I know. I got them =) but these lights need time and patient to do. I put the driver side on mine already but the corner light need some work to fit so i give up. Since i have no extra time and patient.
yup. Get them if you can get them around $200 get it. Is worth it !
Old May 26, 2003 | 10:54 PM
hairris's Avatar
What lights do they need to fit? They won't work off 9004 will they? And if I put all my time into it and money also what would you estimate time and money it would take?
Hairris
Old May 27, 2003 | 12:07 AM
AuToMaX_95's Avatar
Hairris
9004 will not work. The headlight only work for H4. Time about 12 hours i said amd lots of planning and thinking mostly patients. hmm Money none. Except if you want a shop to do the job for you.
R32 headlight converstion is not hard at all, There is 2 thing you need to do
1) shave off everything on the back of your R32 headlights to make it fit properly on your car.
2) cut a bit off the bracket thats holding the fedner were your corner light bolt on to and your headlights. After cutting your corner light should fit fine.
I put on the driver side headlights and it fit just fine, expect the corner doesn't fit. And i don't plan to cut the fender bracket so yeah. Is pretty easy after you think about it. Compare to other Conversion.
Old May 27, 2003 | 04:00 AM
Tatanko's Avatar
Bacon Lover
Does anyone actually have pics of the R32 headlights installed on their Max?
Old May 27, 2003 | 04:05 AM
Kanaka's Avatar
Yes, check out Adrian's page:
http://www.cardomain.com/id/sanjosemaxima
Old May 27, 2003 | 01:55 PM
Joeycurl's Avatar
Turbo95Max has them as well.
Old May 27, 2003 | 02:07 PM
95nissanMax's Avatar
turbo95max has the one piece lights i thought
Old May 27, 2003 | 03:01 PM
sanjosemaxima's Avatar
Sleeps with his maxima!
Matthel... turbo95max has one piece cefiro lights that may actually require more cutting of the body itself to fit.
Old May 28, 2003 | 04:01 PM
hairris's Avatar
thanks for the help!
Hairris!
YourLocalAsian
Aug 17, 2015 02:33 PM
wingsfan24
Aug 15, 2015 07:35 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
dauntlessmax
Aug 5, 2015 10:29 AM
