Why can't I just get a K&N and slap it on?
Old May 26, 2003 | 10:44 PM
thisasian's Avatar
So... why do I have to go out and spend $150+ on a Stillen, JWT popcharger, Frankencar, etc intake when I could just go out and get a K&N and slap it on? I mean... and I know I'm going to get crap for this but... I looked at the stock box, and it looks like... If you could get the right plate to adapt you could attach just about any filter to it. Yes/No?
And... hehe, keep in mind this is college student budget thinking here... I know those eBay CAIs are crap, but couldn't I just use the midpipe from it? or find one like it? What, other than shiny metal, makes the Frankencar midpipe more special than another similarly shaped midpipe? Am I wrong here?
Old May 26, 2003 | 10:50 PM
DJSmitty's Avatar
Too bad search is down. Here you go:
http://www.brianv.net/mods/filter/
and you mind as well go all the way to get a full hybrid intake for an extra $15:
http://www.drwebdesign.com/mymaxima/upperintake.html
Enjoy.
-Smitty
Old May 26, 2003 | 11:02 PM
thisasian's Avatar
Enjoy.
-Smitty
I am amazed at the ghettoness. Thanks Smitty
Old May 26, 2003 | 11:20 PM
maxima_se007's Avatar
The airbox itself is the restrictive part, not jsut the filter. Getting a stillen or jwt etc.. will give you more filter surface area which = freer flowing intake.
Old May 27, 2003 | 12:03 AM
drewm's Avatar
Re: Why can't I just get a K&N and slap it on?
JWT are $116 at http://www.eatricezone.com/
Old May 27, 2003 | 12:10 AM
AuToMaX_95's Avatar
Re: Re: Why can't I just get a K&N and slap it on?
I don't usually give out props But You got a hella nice car! Love the Te-37. black on black...
Old May 27, 2003 | 01:30 AM
Quack 2x's Avatar
This is a kind of late response, so you may have already rigged up some kind of adaptor (sp) already... but in case you haven't, here's another way.
I know there was a thread a long time ago about the home depot adaptor, but I can't pull it up now. The gist of it is that you can get a generic 3" drain pipe adaptor with a square base, and drill holes in the base to line up with the holes in the MAF. A generic 3" inlet K&N cone filter will squeeze over the drain pipe hose, and the whole thing bolts to the MAF. The hose clamp that comes with the K&N will work just fine and clamp it down to the drain pipe, and you're pretty set.
If you're concerned about the thing moving around, just take some aluminum or sheet metal strap and bend it into a bracket, you can use the existing bolts and holes from the airbox.
Hope this helps some,
Quack 2x
Old May 27, 2003 | 06:17 AM
mzmtg's Avatar
Minister of Silly Walks
I got a $20 AutoZone filter and slapped it on. I used the "BrianV" method. If you drill out the rivets instead of just yanking, you wont bend the gold piece very much at all. I used some silicone to seal the gold piece to the MAF. I put a little K&N oil on the filter and away we go...
Old Jul 16, 2003 | 09:03 AM
s0ber's Avatar
does that setup result in a noise increase??? Im guessing it does but very little or ... Since theres no midpipe just the stock resonator.
Old Jul 16, 2003 | 09:34 AM
mzmtg's Avatar
Yeah, it's just as loud as any other open intake.
Old Jul 16, 2003 | 10:52 AM
sean96SE's Avatar
I'm just curious, if you do this filter mod, is there any cutting or permanent change that would keep you from going back to the stock setup?
Old Jul 16, 2003 | 11:25 AM
maximum810's Avatar
...more surface area on the filter to take in all that hot air in the engine bay....heh
Old Jul 16, 2003 | 03:11 PM
95emeraldgxe's Avatar
sure you can do it but you'll still have that crappy resonator
Old Jul 16, 2003 | 04:02 PM
DanDeighan's Avatar
This is probably not what you're looking for, but it is what you requested:
http://www.nismoparts.com/catalog/?section=172
Old Jul 16, 2003 | 04:12 PM
Jime's Avatar
The EBay CAI's aren't crap they are better than the PR CAI's imho because they are much lighter and dissapate heat better because they are aluminum vs steel like the Place Racing.
The only thing that is crap is the filter on most of them but that is easily remedied and even with a very expensive filter they are still much cheaper the the PR version.
Plus you can use it in hybrid mode as well so you have the best of both worlds.
Old Jul 16, 2003 | 06:38 PM
mzmtg's Avatar
http://forums.maxima.org/showthread.php?threadid=231843
Old Jul 16, 2003 | 10:02 PM
s0ber's Avatar
Robert Schneeweis
Jan 11, 2017 06:47 PM
flyry110
Jan 5, 2002 07:17 PM
Gamezilla
Dec 5, 2001 11:37 AM
