so I need new motor mounts...couple of Qs
Old May 27, 2003 | 01:39 PM
luckee2bhere's Avatar
I have figured that I definitely need new ones. I know they are about $260 from Place Racing.
I figure mine have been broken for a while but I didnt know.
Does anyone else sell them?
Is it bad to continue driving my car?
Can I do install? How much to pay someone to install?
Old May 27, 2003 | 02:27 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
how many times did you neutral drop your car?
Old May 27, 2003 | 02:29 PM
never...i have a stick. i race my car if you couldnt tell from my sig.
Old May 27, 2003 | 04:37 PM
beep. beep.
Old May 27, 2003 | 04:38 PM
JeffesonM's Avatar
living out of a maxima...
what are signs of needing new motor mounts? how about transmission mounts?
Old May 27, 2003 | 09:25 PM
http://forums.maxima.org/showthread....5&goto=newpost
click that. i did what they said. I also drove with my hood open slowly and looked through the bottom and noticed it move too much when i hit the gas and let off abruptly like slizan99 said.
Old May 27, 2003 | 09:37 PM
speedtrip's Avatar
Re: so I need new motor mounts...couple of Qs
The place racing engine mounts don't have the best reputation here. The general consensus is that they transmit to much vibration to the rest of the car. Check into some of the homemade motor mounts. I believe there is some information contained in the FAQ.
Unless your mounts are completly destroyed you should be fine with normal driving.
The install is not to difficult if you have the right tools. For the driver side you need a long extension. I used a 20" and 12" extension together to reach the rear mounting bolts.
Old May 28, 2003 | 02:43 PM
i was j/k.....
Mine were broken on my last car, and you could definitely tell.
I failed inspection because of a broken motor mount. I understand that has nothing to do with driving ability, but why not get them fixed at your own leisure than be rushed?
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
