Security Light Help!!!!!!
Old May 28, 2003 | 06:38 AM
WhiteMaxima99's Avatar
My security light came on and stays on when i put it to Acc. The dealer told me to take it to them and that it is prolly the computer any suggestions anyone....... isn't there a way to reset the computer?
Thanks Guys!
Old May 28, 2003 | 07:46 AM
cam_honestiam's Avatar
The first thing that I would do is disconnect the negative terminal on your battery post. Let is sit for a few hours (over night or something maybe). This will often reset the ECU, but I am not sure if it will reset the security computer. It is worth a try. The next thing I would do (make sure your car is unlocked, perhaps with the key in the ignition, but not in the ON or ACC position, just slid into the cylinder) is remove the fuse(s) that are linked to the accessories and keyless entry system. The reason I suggest this is because by doing so, you are breaking any and all power contact that might be allowing your ECU or security computer to store trouble codes and or defaulted settings. This procedure may or may not work, but it is worth a try to save you money.
Typically, if the security light comes on steady, it is signalling that the car is in the arming process. If it is steady continuously, it may be signalling a malfunction. If your alarm is not going off as you drive down the highway, your best bet is to wait until you have done everything that you can. Do not grow impatient with it, just take it a little at a time and try a few things. I promise you that the dealer should be the last resort. It may be just a wire grounded somewhere. Do some investigating and reading about it. See if a friend has a factory service manual and can help with the wiring diagrams. Call another dealership and ask "What might make the security light come on when...." and then call a different dealership to get another opinion.
Old May 28, 2003 | 07:53 AM
njmaxseltd's Avatar
Check the hood latch pin. If it's busted or came loose, your car wount arm and the light will stay solid.
Old May 28, 2003 | 11:43 AM
cool im also gonna try resetting the ecu today that might help....
Old May 28, 2003 | 12:24 PM
njmaxseltd's Avatar
ECU has nothing to do with the security system.
That "black box" is located in your trunk.
Old May 28, 2003 | 02:27 PM
H.N.I.C.95's Avatar
Old May 29, 2003 | 06:40 AM
Is there anything i can do to reset it?? Black box?????in the trunk hum never heard of that.
Old May 29, 2003 | 07:46 AM
Not as new as you think. It just so happens that my diagnosis has led to my own security system working properly. My hood button was broken and my light did not stay on continuosly.
I offered some ideas, but never did I say that they would drill down the solution. Call me a Newbie if you want, but YOU try to figure out what his problem is and offer a better route to fix it.
Originally posted by H.N.I.C.95
Old May 29, 2003 | 08:54 AM
K Ill check on that also I kinda want to take it to the dealer but i dont want them to overcharge me and tell me that I need all this stuff on my car that i dont even need.
Old May 29, 2003 | 11:47 AM
95GreekMaxSE's Avatar
try resseting your alarms BCM unit. lock all doors and close all windows. stick key in ignition seven times ..hazard whill blink twice. Hit the lock key on the remote then hit the unlock key.
Old May 29, 2003 | 01:38 PM
drewbowski's Avatar
just go buy a new alarm. without piezo its not going to help.
Old May 29, 2003 | 02:23 PM
without pezo its not gonna help?????? oops wait..ur a newbie
Old Jun 2, 2003 | 08:31 AM
K I took it to the dealer and they told me my battery $90 doesn't have enough Cranking apms, So I told them to go ahead and but it on. Now I called him this morning and he said my starter was messed up $350(I think cause I was trying to start it to much??) would the starter cause the security light to come on????
Old Jun 2, 2003 | 10:42 AM
mrglynis's Avatar
Does anyone else think it sounds like the immoblilizer was activated? Its ususally signaled by the security light being on. Theres another thread just started with the person saying the same thing. Just a thought.
Old Jun 2, 2003 | 11:08 AM
cool thanks for the info thats prolly whats wrong.....
Old Jun 2, 2003 | 01:01 PM
BryanD's Avatar
Hey Whitemax, Got a call from the dealer and he said that the memory was lost for the keys. They have to reprogram them. 44.00 for Each Key and a 50.00 Tow bill. He asked alot of questions as to how it happened but we could not place anything. Hope it never happens again! Good luck with yours.
Old Jun 2, 2003 | 01:42 PM
Thanks for info. Ill let you guys know whats up with my car in a couple hours.
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
