cruise control won't work above 90?
May 28, 2003 | 03:20 PM
I left late for work this morning, and i had go really really fast(the speedometer was in the triple digits) to get there on time. Before you guys some down on me, understand the highway i was on was basically empty, and there's like 10-20 mile stretchs of flat road and no exits, so THERE WAS NO ONE TO WORRY ABOUT BUT MYSELF. Now my question: Is it just my car, or does anyone else's cruise control stop working past 90mph? If you know, then give me a response, if not DON'T try and find out the answer.
May 28, 2003 | 03:26 PM
your ecu has a limiter for it! Stock thing! Change ecu's if it means that much to you! They all are the same!
Hairris
Re: cruise control won't work above 90?
Quote:
same here.... mine seems to cut out or refuse to set after 85 or so.....
-RMB
May 28, 2003 | 03:29 PM
Yah, Mine does this also.
If I accelerate with the Cruise control buttons, it lets me go a couple miles per hour faster, like 91-92.
I bet it's related to the fact that you can fall asleep with the car doing it's own thing and wreck at 90 mph.
May 28, 2003 | 03:41 PM
Its in the manual as well.
May 28, 2003 | 04:07 PM
All Cruise Controls for the Nissan Maxima will limit the cruising speed to 90 MPH; GLE, SE and GXE alike......
May 28, 2003 | 04:18 PM
Mine goes 1-2 +- 90mph on cruise.
May 28, 2003 | 05:08 PM
Another thing to notice is if you have a 5speed, and you engage the clutch while cruisecontrol is on it will just rev to redline - BAD news...bad design.
May 28, 2003 | 05:25 PM
On my 99 the cruise shuts off when I disengage the clutch. Actually it shuts off when I even tap the pedal. GREAT design!
May 28, 2003 | 05:26 PM
Quote:
If your Maxima does this, there's something wrong with it. Mine will disengage when hitting the clutch, just the same as it does with the brake.
May 28, 2003 | 06:23 PM
Quote:
Hairris
Um, wrong.
May 28, 2003 | 06:53 PM
if i hit the clutch the CC shuts off as well 96 SE
May 28, 2003 | 08:01 PM
my car gets off cc when the clutch is pushed in, somethings wrong with ur cc!
May 28, 2003 | 08:16 PM
Nah.. if you tap the clutch you'll kill the CC but if you just pop the stick out of gear into Neutral WITHOUT touching the clutch it'll bounce off of redline rev limiter till she blows.....
That's an odd design....
-RMB
May 28, 2003 | 08:35 PM
When I have my cruise on it seems like it acclerates and jumps back down and continues to do this like every 10 seconds or so. I watch the speedo and the rpms and they are fine, but I sware it feels like the acclerator is pressed just a tad bit more and you can feel the torque, then it goes back to normal. Anyone have this problem before?
May 28, 2003 | 08:46 PM
Quote:
its probably just adjusting for the grade of the road, or are you talking about something else? sometimes it feels like my cruise is snapping my neck back when i press the accel button or the coast button and then let go...
May 28, 2003 | 08:55 PM
Hairris
should be a 93 limit. i tested it for a long time to find the exact speed and thats what it seemed to top out.
your girl gives good head, mine gives good advice
May 28, 2003 | 09:32 PM
rmb why would u do that?
May 28, 2003 | 09:43 PM
-RMB
And may i ask why the hell you would be popping the stick out of gear without engaging the clutch? WHILE using CC!?!
May 28, 2003 | 09:45 PM
Quote:
May 28, 2003 | 10:46 PM
not a bad design just a bad driver. and you should have a rev limiter so you won't blow your engine
May 28, 2003 | 11:14 PM
Quote:
damn... u need to lower ure ride hahah
May 28, 2003 | 11:19 PM
Quote:
Yeah I know just got the rims 2 weeks ago and I just got everything to lower it last weekend. So is gonna get lower this weekend
May 28, 2003 | 11:35 PM
cool
haha i remember when my friend was teaching me how to drive stick on his brand new rsx type S... i had no problem till he let another friend of ours try. The fool tried to shift w/o pushing the clutch in and was like "hey it's stuck" while the car was making grinding noises. Damn it was funny
May 28, 2003 | 11:40 PM
If you really think about it... Are you really crusing at 90 mph?
May 28, 2003 | 11:42 PM
nah, you would be "driving really fast" at approximately 84.6 mph
May 29, 2003 | 05:16 AM
You can shift just fine without using the clutch. It just takes a little practice.
May 29, 2003 | 05:24 AM
Hey check to see if your throttle cables are tight. On the TB one is for the cruise and one is for the pedal check both. I had some slack in mine and it was causing the same thing.
May 29, 2003 | 05:55 AM
There is nothing wrong with this. When you are going up a hill it has to give an extra umph! to maintain speed. If you are going down a hill, it needs to take a breather. It does this very well i might add. It's very subtle. Just to let all you know, my cruise works wellll above 90mph.
May 29, 2003 | 07:03 AM
I'm assuming it's an automatic....
If so, it's probably just the 'lock-up' torque converter kicking in and out. The torque converter has a 'clutch' inside that locks the unit up direct in high gear under light loads. My car cruises around 2700 rpm at 80mph. On a steep hill (common around here) the converter will 'un-lock' and the revs will jump up to around 3000 until the hill flattens out a little.
Good Luck!
May 29, 2003 | 03:06 PM
Hairris
you're absoloutely wrong! All ECU's aren't the same! Think before you post!
Anyway, wow, i leave this thread expecting one answer and find 3 pages. I also noticed that the CC buttons don't always work. I'll hit RES, and it won't kick in. I'll wind up having to accelerate by the pedal and then hit SET again....i dunno, maybe my CC switch needs to be replaced.
I also noticed that the pedal will move itself slightly will CC is on, like it goes "limp" when you turn CC on, but i'll readjust my legs, and it'll be further down, or higher up.
May 30, 2003 | 05:57 AM
Quote:
True, but it's not the best thing to do for your syncros....and definitely not something you need to be doing at 90mph with the ****ing cruise control on.
Re; the original post: Mine won't set above 90 too. That used to annoy me when I would drive Boston -> Rochester on the thruway. My CC also disengages when I touch the clutch.
May 30, 2003 | 08:09 AM
-RMB
It won't blow, it willjust bounce off the rev-limiter which you could do all day. It's definately not good for the motor to bounce off the rev-limiter for extended periods, but it will not blow the engine. Now if you downshift in 2nd at 90mph, then you run the risk of blowing the motor because the rev-limiter won't work. No rev-limiter on any type of car would stop the motor from spinning.
Dave
May 30, 2003 | 08:59 AM
Uh.....that doesn't happen to me....5spd conversion with 5spd ECU - When depressing the clutch, cruise turns off and the revs simply drop.
Maybe this is a benefit of a conversion.....?
May 30, 2003 | 10:01 AM
no, his car is just fubar'd
