Changing tranny fluid to redline...???
I'm going to be doing the tranny fluid change over to redline next week. I have a question though, they dont recommend you mixing for instance synthetic oil and regular oil as they dont mix....so is it ok to mix the redline tranny oil and whatever doesnt drain out of the system...since I will only be using the drain plug on the tranny?
Re: Changing tranny fluid to redline...???
I just had mine changed to Redline. I asked the same question. Apparently, you don't flush manual trannies, so it's really your only option. I did it, and the Redline made a BIG difference. Cold shifting is much much better now.
I guess here is my thought on all this. Notice all the people blowing a gear...some are blaming it on ACT clutches...well...I've noticed they are also running redline tranny fluid and if its not mixing well I bet the gears arent getting proper lubrication.
Only my $0.02.
Because he has no idea. The dino/synthetic lubs are compatible.
Originally posted by StygianMax
What do you suppose prevents two different tranny oils from "mixing well" and being effective to lubricate the gears? I figure the gears are spinning so fast that the oil gets kicked up all over in the tranny case. And as long as the density of each of the two fluids is relatively similar, they wouldn't separate quickly.
Only my $0.02.
Only my $0.02.
Ok well I was personally confused since they recommend not mixing synthetic and regular oil. Thanks for clearing it up.
-RMB
I suggest you don't trust that particlar group of "they" much longer.
they is an elite group of people who know things that I dont.........
No I was refering to the Redline company.
I bet that would explain all the prbs I have...I wanted to thank jeff for all his smarta$$ comments in this thread.
Anyone else like to thank jeff....jeff take a bow..everyone is clapping for you
i was wondering the same but didnt get as many responses when i posted a thread
, i want to switch to redline fluid as well in my auto tranny and am planning to drain from underneath,
is anyone sure of how much fluid will come out if i just drain it from under pulling the drain plug?
, i want to switch to redline fluid as well in my auto tranny and am planning to drain from underneath,is anyone sure of how much fluid will come out if i just drain it from under pulling the drain plug?
I Had mine changed over to Redline synthetic at about 20000 miles. Two months later, time for a new tranny! I had the lube changed by a local performance shop. Maybe It's just coincidence, but I haven't used redline since.
Just my 2 cents.
Just my 2 cents.
Originally posted by GTRMAX99
It was actually replaced at about 32000. It's a 98 with a manual.
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
