Procedure for flushing brake fluid
Old May 30, 2003 | 06:16 AM
Erik G's Avatar
I just installed my second set of Porterfield 4S pads. This time I also changed the brake hardware kit, which included the shims and guides. I want to flush and replace the brake fluid, as it is at least 3 years old. What is the proper procedure for flushing the brake fluid? I do not have speed bleeders so I realize that this will be a two person job. I have read in shop talk that the proper order is (right rear, left front, left rear, right front), while I’ve read elsewhere that you start at the wheel furthest from the M/C and proceed to the next closest (right rear, left rear, right front, left front). Which way is correct? Also does it matter if you leave the bleeder valve open when purging out the old fluid, then once the new fluid comes through you start to close the valve when the brake pedal is released. Thanks for your response
Old May 30, 2003 | 06:35 AM
njmaxseltd's Avatar
Start anywhere, get the Master Cylinder and one line to run clean, then the others will go fast because your drawing on totally clean fluid in the reserve.
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
