Best way to REPAINT Wiper Arms
Old Jun 1, 2003 | 09:36 AM
Kevlo911's Avatar
Kevlo for President
hey everyone,
i was wondering which paint and the best way to repaint my fading wiper arms?
Old Jun 1, 2003 | 09:40 AM
95_SE_5spd's Avatar
i'd probably have to say something like rustoleum, it's what i use at work for wiper arms and trailer hitches and what not, it seems to hold up. so pretty much anything that can withstand the rigors of weather changes.
J
Old Jun 1, 2003 | 10:04 AM
deezo's Avatar
Re: Best way to REPAINT Wiper Arms
Originally posted by kevlo911
hey everyone,
Flat black rustolium. I was thinking about polishing mine.
patel_anu's Avatar
hey everyone,
time to get a new car...haha
j/k man, i need to repaint mine too..half of it is turnin silver
Old Jun 1, 2003 | 10:41 AM
1996blackmax's Avatar
Re: Re: Best way to REPAINT Wiper Arms
Same here. I think I'll try the flat black rustoleum next weekend.
Old Jun 1, 2003 | 12:59 PM
maxNYC's Avatar
You should remove the wiper arms from the car
Sand them down so that the paint will stick better.
I used steel wool.
I used ordinary flat black spray paint. Rustoleum shoudl work just as well. You only need a single coat.
I did this over a year ago and they still look great.
good luck
Old Jun 1, 2003 | 02:39 PM
sandman1098's Avatar
Just make sure you get any rust if there is any.....
Old Jun 1, 2003 | 04:02 PM
speedtrip's Avatar
hey everyone,
I went with a satin black. It's a good compromise between flat and glossy. The paint has a little bit of luster to it and I did not have any problems with glare coming off the wiper arms.
Old Jun 2, 2003 | 06:09 AM
endus's Avatar
An atavistic endeavor...
Good info guys....I need to do this some time too.
Old Jun 2, 2003 | 06:15 AM
Str8ridin's Avatar
Cool thread...I need to do mine as well.
BTW, I haven't looked closely yet, but is there a special way of taking the entire arm off?
Old Jun 2, 2003 | 06:22 AM
abstrakt79's Avatar
all i did was pull it into the garage, mask off the windshield and the hood and the side mirrors and then sprayed black satin on them and now they are all black again...no complaints here, no need to take the arms off.
Old Jun 2, 2003 | 06:30 AM
njmaxseltd's Avatar
Clear coat them after you spray them black. Might keep them looking good longer.
Old Jun 2, 2003 | 07:52 AM
cam_honestiam's Avatar
The wiper-arm nut is typically reverse-threaded. So, if you take them off of the car (less risky than trying to mask everything off, and cheaper if you don't have plastic or newspapers) using a socket wrench, try "loosening" in the opposite direction normal (normal: righty-tighty, lefty-loosey....).
I did this to my Honda with a gloss black...bad idea (without a clear coat) cause they just chipped a few months after.
Old Jun 2, 2003 | 10:45 AM
XXXL Cracker's Avatar
I removed them, used a flat black paint and clear coated them. When you replace them, make sure the wiper arm is put in properly as it will affect the area covered by the wiper blade.
D
Old Jun 2, 2003 | 10:50 AM
Jeff92se's Avatar
I'm needing a caw
Engine paint. Very stuff stuff. But limited colors.
Old Jun 2, 2003 | 06:24 PM
white95max's Avatar
I'm guessing that you could probably just use black touchup paint, then put some clear coat on too if you wanted. I work in a body shop so I could get some touchup paint for free and see how it works for me.
I'll try it and post afterwards.
Old Jun 3, 2003 | 04:21 PM
Kevlo911's Avatar
Kevlo for President
thnx all, ima go with flat black and keep the arms on
Apr 16, 2020 05:15 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
RealityCheck
Oct 2, 2015 06:34 PM
leatherneck
Sep 30, 2015 09:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
