Question on Doing a ECU computer Conversion... OBD1 (more)
Old Jan 26, 2001 | 11:46 AM
Stillnmax's Avatar
I know the legality issue of doing a conversion im goin to mention but is it possible.
(hypothetically )
Im wondering how hard it would be to do a OBD1 conversion to a 99maxima. i know on BMW's more specifically to the 97m3 you can do an OBD1 conversion.
The result is a very noticeable one. I was wondering how hard it would be to do this on a Max.
Old Jan 26, 2001 | 05:20 PM
The New CLIMAX's Avatar
Welll you would need to do alot of rewiring. JWT
did this on a 2K Maxima ans switched its ECU with a 95-96 ECU, so you should be able to as long as you have the $$$ or knowledge to rewire it all.
Old Jan 26, 2001 | 10:58 PM
Dave B's Avatar
Not DAVEB the parts guy
The conversion is completely impossible. Why? Because the 95 Maxima is OBD II compliant. If you don't believe me, check out http://www.obdii.com and you'll see that the California Air Resource Board lists the 95+ Nissan VQ30DE was OBDII compliant. It is a complete myth that the 95 was ever OBDI.
Nissan designed the USA version Maxima with the intention of making it OBDII compliant when it entered the market.
Dave
Old Jan 29, 2001 | 05:53 AM
95Max's Avatar
The 95 max is both OBD1 and OBD2 depending on when it was made. If before feb/mar 95 its is OBD1.
Old Jul 28, 2010 | 03:38 AM
roly91's Avatar
so if i want to put a motor from 96 obd2, in to a 95 obd1 what is it that i have to do to make it work?
Old Jul 28, 2010 | 06:21 AM
Kevlo911's Avatar
Kevlo for President
wow you couldn't find a newer thread?
ALL 4th gen max's are OBD2
Old Jul 28, 2010 | 11:30 AM
FallenOne's Avatar
what the pissed off alligator said. You should be able to just plug and play everything.
Old Jul 30, 2010 | 03:39 AM
roly91's Avatar
i read somewer that if the car was made b4 march 95 then is obd1. but not sure
Old Jul 30, 2010 | 03:51 AM
ColombianMax's Avatar
You sure did, you read it on post #4 but that post is incorrect.
Also +1 on what the pissed off Alligator said
Old Aug 2, 2010 | 03:14 AM
roly91's Avatar
All cars and light trucks built and sold in the United States after January 1, 1996 were required to be OBD II equipped. In general, this means all 1996 model year cars and light trucks are compliant, even if built in late 1995.
so 95 maxima can be obd1 or 2. i have a 95 siting in the back yard with obd1.
Old Aug 2, 2010 | 05:13 AM
Trini Boom's Avatar
Listen here buddy, the (% you have is OBD-II compliant. Nissan was ahead of the curve in making it standard when they produced the 4th gen Maximas. Your is located on the passenger side floor near center console. So Stop saying its OBD-I because it is not!!!!!
cruce91
Sep 20, 2015 10:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
conansriver
Sep 11, 2015 10:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
