Seized Calipers?? I think??
Old 06-02-2003, 12:03 PM
wordjb's Avatar
Has anyone with a 4th Gen had any problems with their rear calipers. I recently replaced my rotors and pads and noticed that the rear calipers were a bit tight. I tried and tried to compress the calipers to push the fluid back into the master cylinder but the rear calipers wouldn't budge. To make a long story short I ended up putting the old pads back on the rear because I could not buy enough room to put the new ones on. I was just wondering if this means that my calipers are seized? What can I do, are they shot?
wordjb is offline
Old 06-02-2003, 12:30 PM
njmaxseltd's Avatar
You need to twist them back in. They will not compress like the fronts do. There are two nubs that you can get a good set of needle nose pliers onto to twist it back. Or just buy a caliper tool at a local automotive supply store.
njmaxseltd is offline
Old 06-02-2003, 01:20 PM
XXXL Cracker's Avatar
Get a caliper tool. You cannot compress the rear piston. You can do a Rent a tool at an AutoZone store. They let you use the tool for free, just need a credit card to secure it.
If the pads are extremely worn, they will be difficult to turn in.
Good luck, it is not too bad!
D
XXXL Cracker is offline
Old 06-02-2003, 03:05 PM
time2reup's Avatar
but yes we have had more people talking about seized calipers recently....
time2reup is offline
Old 06-02-2003, 08:06 PM
wordjb's Avatar
Thanks for all of your help guys, really glad I don't need to buy new calipers, hoping to finish the job tomorrow. Thanks again.
wordjb is offline
Old 06-02-2003, 08:14 PM
rmb
rmb's Avatar
Needlenose pliers work just fine too.....
-RMB
rmb is offline
Old 06-02-2003, 08:34 PM
BigJayx23's Avatar
u guys know wat i need to buy from nissan to rebuild a rear calipers???? any site u guys mite know where i can buy kits to rebuild them?? i know one of my rear ones are shot.. because its a ***** to turn them.
BigJayx23 is offline
04-16-2020 05:15 AM
BkGreen97
04-02-2016 05:47 AM
imported_Nismo_max
09-21-2015 07:24 PM
bbsitum
09-11-2015 04:55 PM
beerman1378
09-08-2015 02:19 PM
Quick Reply: Seized Calipers?? I think??
