Front suspension ticking
Old Jun 2, 2003 | 08:31 PM
polishpunk68's Avatar
my gf's 96 maxima has a moderately quiet ticking noise coming from the strut/suspension area in the front when the wheel is turned when the car is either standing or moving very slow. It never happens when the car is moving above say 15mph...
Occasionally also there is a semi loud bang sound coming from the same area after the wheel is moved the first time after the car has been standing for a few hours. This only happens once in a blue moon though, not often at all.
The dust boots on her struts are torn off, so could the struts have been damaged by that and make noise now? Or could it be the strut mounts?
Also, is it safe to drive around with the dust boots ripped like that?
thanks
Old Jun 2, 2003 | 09:32 PM
Stillen_I30's Avatar
http://www.motorvate.ca/mvp.php/400
Old Jun 2, 2003 | 09:35 PM
RobUsaf81's Avatar
yea thats a bad thing, get them replaced as soon as possible
Old Jun 2, 2003 | 09:53 PM
ouch.. thanks, how much do they cost and is it hard to replace yourself?
Old Jun 2, 2003 | 10:31 PM
RobUsaf81's Avatar
no i think your struts are fine, its your CV joints that are gonna need replacing, by what your describing, the ticking and popping noises you hear when you turn the steering wheel means your CV joints are going and you need new axles. how soon you need them depends on their condition but i would do it right away for saftey, get a good mechanic to inspect them to see if they need replacing for sure, as for how hard they are to replace yourself, thats up to you and how good you are with cars.
Me personally, i would have a very mechanically inclined friend do it for me cause it doesnt sound easy to do. just my opinion
Check out www.raxles.com ive many good things about them here on the .org
Old Jun 3, 2003 | 04:40 AM
MaxEffect414's Avatar
checsh yak chimash polish punk, lol
Old Jun 3, 2003 | 10:31 AM
the instructions for doing it yourself are right on that link...only you would be able to determine whether you think you will be able to do it by yourself or not.
Old Jun 3, 2003 | 11:13 AM
MyGray96SE's Avatar
My Max makes that sound too. It turned out to be my springs. I wrapped the top coils (bottom were already done) and it went away...
Old Jun 3, 2003 | 01:48 PM
blizz20oma's Avatar
I'm so hood
if I'm not correct, shouldn't have to worry about wrapping oem springs (I'm assuming she's OEM, maybe I'm wrong).
Check the CV boots and see if both of them are torn, or if it's just one joint you have to worry about.
Old Jun 3, 2003 | 02:26 PM
yes she has OEM springs..
I called up raxles.com and talked to one of their guys, he said that it is highly unlikely that its the CV joints or axles.. next time I see her car I'm gonna listen and see where exactly the sound comes from and do some thorough testing.
Old Jun 3, 2003 | 04:25 PM
TooMAX's Avatar
Might be the strut bearings
Old Jun 3, 2003 | 07:35 PM
I just listened to it with the hood open to try to see where the ticking comes from... it seems to be coming from near the top of the engine area, nowhere near the strut towers or wheels...
also, the ticking is a lot quieter under the hood, I actually had to really listen to it to hear anything, it sounds louder from inside the car... it also is loudest when initially starting to turn the wheel then it quiets down...
I had her drive in small circles and nothing, no sound.. its pretty much only when its standing...
could this be power steering related? or steering in general?
Old Jun 4, 2003 | 05:40 PM
^^^ anyone know?
Old Jun 6, 2003 | 01:19 PM
I just found out it was the strut mount on the passanger side.. the driver side is going too but doesn't make noise yet.. so they both need replacement..
are the KYB ones the best strut mounts? are they the only strut mounts?
wyobbagy
Jan 3, 2023 12:03 PM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
A32goldylocks
Sep 2, 2015 06:39 AM
