Engine Removal Tips...HELP!
Old Jun 5, 2003 | 03:21 PM
DMaximus's Avatar
I'm about to swap engines in my 97 Max, but I can't seem to get my car jacked high enough to drop the engine through the bottom.
Is it possible to just drop the transmission through the bottom and remove the engine through the top?
Old Jun 5, 2003 | 03:36 PM
Kevlo911's Avatar
Kevlo for President
i thought u had to remove it from the top with an engine lift
Old Jun 5, 2003 | 03:52 PM
DMaximus's Avatar
The manual says to remove the engine through the bottom.
Old Jun 5, 2003 | 04:07 PM
slizan99's Avatar
i would think that you take it out through the top
Old Jun 5, 2003 | 04:20 PM
DMaximus's Avatar
Oops!...my bad. The manual says that when removing engine transaxle combination, it is best to remove it from the bottom.
Old Jun 6, 2003 | 04:00 AM
carnal_c30's Avatar
Former Sponsor
ehehe then you run into the problem that you have now
put the jack on a block of wood?? a few blocks of wood? (better be steady as hell )
otherwise unbolt the tranny and do each one seperately
Old Jun 6, 2003 | 05:03 AM
ejj's Avatar
ejj
That is what the FSM says, correct. However, if you don't have a lift, that's next to impossiable. People have, and I plan on: removing the tranny from the engine with the engine still in the car. Then remove the tranny by going out the bottom (duh) and remove the engine with a hoist from the top.
Seems the easiest.
Old Dec 28, 2008 | 09:27 AM
Kevlo911's Avatar
Kevlo for President
DO NOT bump old threads to get your post count up. I will delete the worthless posts and might even ban if you keep doing it.
Mar 12, 2020 12:06 AM
knight_yyz
Oct 24, 2015 08:05 AM
Colossus
Sep 9, 2015 05:46 AM
