ball joint problem
Old Jun 6, 2003 | 03:29 PM
cantgofast's Avatar
ball joint problem
I am replacing the lower balljoint on my 95 maxima and am having a problem. I have the control arm totally free, but the ball joint will not come out of the control arm. Does anyone know if it is pressed in or how it might be attached to the control arm? I hope i am not being too vague, thanks for any responses!
Old Jun 6, 2003 | 05:44 PM
boybilly's Avatar
Re: ball joint problem
It is pressed in. You will need to find a shop with a hydraulic press to take out the old one and press in the new. Shouldn't be too expensive.
Old Jun 8, 2003 | 06:07 PM
ejj's Avatar
ejj
http://forums.maxima.org/showthread....ball+AND+joint
May help you a bit.
Old Jun 8, 2003 | 08:08 PM
Mishmosh's Avatar
What are symptoms of a bad ball joint?
At low speeds, I can hear a metallic crunching noise that is intermittent. After working on the spring/strut assembly on that side several times, I'm pretty sure some other suspension component is amiss. Problem is, everything appears to be normal. For the life of me, can't tell where the noise is coming from. I am thinking maybe the control arm bushing is shot but don't know how to test it.
Old Jun 20, 2003 | 05:30 PM
scoobs's Avatar
All you need is a ball joint press that you could rent at any Murray's or Pep Boys.
Old Jun 20, 2003 | 07:33 PM
klymkow's Avatar
where do you buy just the ball joints without the control arms?
I haven't come across any separate from the control arm.
Tim
James92SE
142
Jan 2, 2024 09:23 AM
AaronL
Nov 15, 2020 11:52 AM
ivorton23
Sep 26, 2015 09:47 AM
homewrecker
Sep 24, 2015 07:01 PM
Bonka
Sep 14, 2015 11:18 PM
