Levoc Shifter (auto) Overdrive button- Press halfway
Old Jun 8, 2003 | 12:03 AM
Bgohan's Avatar
Anyone else notice the overdrive button on the Napolex Levoc auto shift **** works when slightly pressed, without having to click it in and out? Works good for dropping out of overdrive gear in corners or for passing, then you just let off a little and it goes back into overdrive.
Old Jun 8, 2003 | 03:22 AM
redmaxpa007's Avatar
i SeE what you did therE
never noticed that before.. i will have to try it
Old Jun 8, 2003 | 11:41 AM
kushane's Avatar
hehe...I swapped my 96 GXE auto shift lever for one from a 01 (leather wrapped) shift **** and the O/D buttons are different. On the 06 - it was press on / press off(clicks and stays pressed until released) and the 01 was a press for OD on and press again for OD off.
What happens now it that when I press the button on the shifter - it kicks to third but doesn't stay there unless I hold the button down. SO I also wired a seperate button (in parallel to the shifter **** button) and now I can momentarily hit OD with the shifter or keep it on with the seperate button.
Kinda like what you were talking about....hmmm maybe I should the got the levoc shifter to begin with and save myself all that chopping and welding to retro-fit the shift ****.
Old Jun 9, 2003 | 04:07 AM
Pizatt's Avatar
I noticed it with mine, I just tap it slightly and it comes on... its just a real sensitive button!
BobTX10
Oct 7, 2015 08:43 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
atriuum
Sep 28, 2015 01:19 PM
