KYB Dust Boots/Bump Stops?
Old Jun 8, 2003 | 11:47 AM
Bmr4life's Avatar
I saw these at cattman.com and was wondering what they are for. I know the dust boot part is to keep the springs clean/protected from dirt but what are the bump stops. I thought our Max's already had bumpstops, what do we need these new ones for. Are these things good to buy when replacing all the suspension parts and will these help reduce noise? thanks
Old Jun 8, 2003 | 12:00 PM
ny96max's Avatar
the bumpstops are apart of the dustboot asssembly.... The KYB boots are designed to give your suspension better travel after you install lowering springs. I believe its up to a 1/2" more travel with these boots vs. OEM boots.
Ant
Old Jun 8, 2003 | 12:33 PM
Bmr4life's Avatar
oh tight, i guess i will get those then since I plan on using H&R springs. thanks
This will fit the H&R springs right?
Old Jun 8, 2003 | 01:41 PM
ThurzNite's Avatar
If you do a search, you'll find some members not happy with the kyb mounts. I was under the impression that the mounts include the bump stop and dust boots. I guess I'm wrong.
Jae
Old Jun 9, 2003 | 10:05 AM
phenryiv1's Avatar
Mod her. Ate her.
The KYB dustboots and bumpstops are fine- it is the KYB strut mounts that are junk. Check out the last page or so of the 4th gen FAQs for info on the KYB dustboots w/ integrated bump stops.
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
maxima-junky
Oct 7, 2015 06:13 PM
BobTX10
Oct 7, 2015 08:43 AM
