car makes squealing noise when im driving, and changes in tone with speed...
Old Jun 9, 2003 | 06:35 PM
kingrukus's Avatar
no more maxima...
Does anyone know what may be causing this? It squeals at the left front wheel after I drive it really hard, and changes in tone according to my speed. I am thinking it has to do with a bearing or something. Does anyone know what would cause this?
Old Jun 9, 2003 | 06:41 PM
kingrukus's Avatar
no more maxima...
Also this happens both when my clutch is engaged and when it is not.
Old Jun 9, 2003 | 06:51 PM
Maxima95Tuner
This leads me to think it might have to do with your CV boots and joints. Get under there and check those out, make sure everything looks ok.
Old Jun 9, 2003 | 07:48 PM
kingrukus's Avatar
no more maxima...
But this only acts up after a really hard session of driving...I mean why would that happen? hmm....the car is still under warrenty...I may take it in and have all sorts of stuff changed.
Old Jun 9, 2003 | 09:19 PM
FLO_BOY's Avatar
my first thought was belts...especially if the noise changes as the RPMs do...
FLO_BOY
Old Jun 9, 2003 | 09:26 PM
kingrukus's Avatar
no more maxima...
I dunno...it really sounds as if it is coming from the left front wheel.
Old Jun 10, 2003 | 04:49 AM
thanpto's Avatar
If the noise comes on after some duration of driving and it's more noticeable at low speed, it's probably the wheel bearing seals or the bearings.
Old Jun 10, 2003 | 05:22 AM
njmaxseltd's Avatar
Brakes
Old Jun 10, 2003 | 02:39 PM
kingrukus's Avatar
no more maxima...
Hmm...I think this is exactly what it is, I am going to have it checked out.
Old Jun 10, 2003 | 02:40 PM
kingrukus's Avatar
no more maxima...
Originally posted by njmaxseltd
Brakes
I thought it might have been this, however there does not seem to be any contact with the brake and the rotor when the break is not pressed.
Old Jun 11, 2003 | 11:00 AM
maximafever's Avatar
it could be the shim on the brake because the brake pad is low I had the same problem so I took the shim off because that noise is nerve racking. Just remember that is time to change yourr brakes.
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
02PearlSE
Oct 7, 2015 02:12 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
