Read, Pre 2 feb 1996 construction
Old Jun 10, 2003 | 11:11 AM
MarcGXE95's Avatar
Timing chain tensioner replacement. Service Buletin 27 july 2000, classification:EM96-008a, Reference:NTSB96-065a.
Simptomes in earlyer stages, when cold at start-up there is a small ratle in the timing chain area and it disapears when warm. Later simptoms are generaly ratles that are more persistent and comon.
It's a long weekend job and must good meticoulus mechanic and well equipped (including service manual).
Note that the new tensionners and guide are slightly different and you should not replace only the tensioner.
Old Jun 10, 2003 | 11:32 AM
dave harms's Avatar
Did you do this on your car?
I'm currious... I've got a 95GXE also...
What did the parts cost you?
When did you do it? How many KMs?
thanks,
dave h.
Old Jun 10, 2003 | 12:44 PM
MaximaSE96's Avatar
Maxima Owner
is this a dealer recall PLEASE SAY YES
Old Jun 11, 2003 | 12:02 PM
MarcGXE95's Avatar
Sorry it's not a recall! My car has 147000km and the job is not expensive the guide and tensioner and other gaskets the way to the cover, around 100. But the job it's self is time consuming. When reasembling you must clean verry (removing the old sealent with a plastic scraper, not to scratch the surfaces)well the components if you want the liquid gasket to seal properly.
Old Jun 11, 2003 | 12:08 PM
MarcGXE95's Avatar
Sorry it's not a recal, even tough the new tensioner assembly is different. My Max has 147 000Km on it. The job is not expensive, maby 120.$ for the tensionner and othe seals and gaskets to be replaced on the way to the cover. But it's time consuming to clean touroughly everything for proper reassembly.
Old Jun 11, 2003 | 12:22 PM
DougsfastZ's Avatar
All Black Max
That explains the small rattle I have when the car starts up when its cold.
I'll live with it.
Doug D
Old Jun 11, 2003 | 01:15 PM
MaximaSE96's Avatar
Maxima Owner
i got some mechanice buddies that are gonna help me do mine up
Old Jun 11, 2003 | 02:25 PM
95GreekMaxSE's Avatar
what happens if you just live with the rattle. Can problems occur like the tensioner breaking???
Old Jun 19, 2003 | 09:42 AM
MarcGXE95's Avatar
When the timing chain rattles it slaps against the guids thus wearing them prematuraly. It will become more persistent to constent and will cause crackes on the chain rolers and links and then the end.
Doing a engine oil flush to ensure the conduits are clean and flow well, use a OEM oil filter. If it still hapens check out the service bulletin.
Old Jun 19, 2003 | 10:10 AM
RAZER's Avatar
When i start my car it makes a squealing noise, is this also the cause? and it also makes a clicking noise while the car is running.
Old Jun 19, 2003 | 12:57 PM
KMax2988's Avatar
The squealing noise is probably a lose belt. The clickin noise might be the good ol Nissan injectors. If it's the noise I'm thinkin bout, it's normal.
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
maxinout93
Oct 31, 2015 02:04 AM
