Custom Interior Lights
It's easy. For the door lights use 194's. get them at superbrightleds.com now as for the window switches. pop the plastic off with a flat head screwdriver. then pop off the container and be careful not to drop anything especially the button contacts. if you have a sottering iron then unsotter the led and sotter the new one (keep in mind the polarity and size of the led. then just put everything back togeather and you got custom lights. Same goes for the driver side window switches but there are 6 leds. As for the back ones those led's are surface mounted so you cant really do anything. Hope this helps. If you need more detail email me.
Originally posted by imlikewoe
For the window switches: pop the plastic off with a flat head screwdriver. then pop off the container and be careful not to drop anything especially the button contacts. if you have a sottering iron then unsotter the led and sotter the new one (keep in mind the polarity and size of the led. then just put everything back togeather and you got custom lights. Same goes for the driver side window switches but there are 6 leds. As for the back ones those led's are surface mounted so you cant really do anything. Hope this helps. If you need more detail email me.
I dont know if you can do this on a 99 but it should work. As far as how small to get the leds just follow the directons and look at the size and then find something at radio shack that fits. (the smallest led's that I found at radio shack were the ones that fit.
Hey, looky here..the Search is thy friend
http://web.csuchico.edu/~ggross/LED.html - Blue Window Switches
https://maxima.org/forums/showthread...5&pagenumber=1 - Different color clock backlight
I don't know if PIAA makes them, they should. I currently use PolarG bulbs in my interior. The number for the maplight was M26 (P8716W), I got them from Ken (Stealth_Max or Stealth Max). He's a good person, you can prob contact him becasue I knwo he deals PIAA and lots fo other stuff too.
-Jeff
-Jeff
I don't know, link works perfectly for me. Try to search for it, thread title: https://maxima.org/forums/showthread...5&pagenumber=1 Posted by: Mad Dhan
i know it sounds cheesy but all i did was buy a blue transparent folder and cut it to the perfect shape and put them behind the lenses. lights up much cooler than just with bulbs and gives the car an easy to the eye look. sometimes i think it's kinda dorky but everyone seems to like it.
sdotcarter
09-02-2015 09:53 PM
rbaker100
08-28-2015 08:11 PM
