read if you bought ebay CAI for 80 bux
Old Jun 14, 2003 | 01:15 AM
Max Noob's Avatar
which kits are the bomz one..i see one with yellow rubber clamps and a grey tubing for like 55 plus shipping
and i see another one with chrome or silver piping with blue rubber clamps for same price on ebay.. are they all bomz??
which one has the better filter and bigger piping diameter..anyone know? thank...i was about to buy one right now but cant figure out which one is "better" . thanks ahead for any feedback.
Old Jun 14, 2003 | 01:25 AM
maximamoose's Avatar
Is there a reason that you want a CAI? Why not just get a ram air intake? NO drilling or cutting required, and yields the same hp
Old Jun 14, 2003 | 01:47 AM
Max Noob's Avatar
overall gains are the same but from what i heard cai give that extra power more in the low-mid range end and ram intakes put it more in the top end..i dont take my car over 4.5 k too often so i want my gain to be in the low - mid range..if the info i got was wrong.someone please correct me..
Old Jun 14, 2003 | 01:51 AM
Stick or auto? I think that the frankencar gives good mid power too. That's what I have. I had that all by itself for a little while, then got the y and b put on. I would really recommend a ram intake.
Old Jun 14, 2003 | 02:05 AM
Max Noob's Avatar
5 speed... frankencar is the one with the longer pipe but isnt cai right..
Old Jun 14, 2003 | 02:08 AM
Right. It goes almost to the edge of the "engine wall" if you will. I don't know exactly what it's called, but there.
That's not my car. just to let you know
Old Jun 14, 2003 | 02:27 AM
Max Noob's Avatar
this is what they call the hybrid intake right...hmm.thanks alot maximamoose.. ill prolly get this one instead then since i read drwem's thing and it says the hybrid ones make the most mid range power...not sure i really want to drill holes in my car for the cai. ebay has an imitation of the frankencar intake from BOMZ too.. its like under 50 bucks..ill bid on it tomarrow.. thanks man..
Old Jun 14, 2003 | 02:40 AM
There you go! Good choice. Get ahold of dmbmaxima2k2 and see if he can hook you up with a deal!
Old Jun 14, 2003 | 03:42 AM
Max Noob's Avatar
he sells them??.ill pm him right now
Old Jun 14, 2003 | 04:25 AM
D1NOnly34's Avatar
so what is the best intake to get on ebay right now?
Old Jun 14, 2003 | 05:19 AM
Jime's Avatar
Get the BOMZ CAI or a knockoff, they are aluminum, better than the Place Racing CAI imho and you can use it in hybrid mode too just like the frankencar.
Plus its much cheaper than either and you have two choices of configuration.
Old Jun 14, 2003 | 05:40 AM
D1NOnly34's Avatar
Like this?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419181777
It doesnt seem to have all the parts needed. Correct me if I'm wrong though.
Old Jun 14, 2003 | 05:45 AM
stephenlc's Avatar
Originally posted by D1NOnly34
Like this?
Ok, your wrong, that is a hybrid intake.
Old Jun 14, 2003 | 05:47 AM
D1NOnly34's Avatar
Mwahahahaha. It said BOMZ, thats why I linked it (unless you're joking =X) So then someone find me one of the good ebay intakes? I'm an intake n00b. I want more than just the "cone filter" that I have now. =/
Old Jun 14, 2003 | 05:57 AM
Jime's Avatar
Like this?
Yes, that is a hybrid, (BOMZ makes both) get the CAI, then you can use it in either mode, give yourself an option.
Old Jun 14, 2003 | 06:01 AM
D1NOnly34's Avatar
Sorry im kinda lost. Is that a good intake, the one that I linked? Does it have all the parts needed? How do you pick what mode you want? What options do I have with it and what are the advantages of each option? Is that intake worth it?
Old Jun 14, 2003 | 06:06 AM
Jime's Avatar
That one is a hybrid, get the CAI one with the other longer curved pipe as well, its not much more and then you can use it as a CAI or in Hybrid mode.
That one is ok, I just think for an extra few bucks the CAI one will give you the option of using it either way, then you can decide which one is better for you.
Old Jun 14, 2003 | 06:10 AM
D1NOnly34's Avatar
I see, so you say get the one that has the longer and more curved pipe, correct? Will it be so long to go into the fender? For a true CAI i would assume so. I really dont mind the short ones, where the filter is still visible and is sitting an top of the lower stock airbox peice.
Old Jun 14, 2003 | 06:26 AM
D1NOnly34's Avatar
Is this one interchangeable? By that I mean can it be a true CAI and in the fender, or if I want can it be in the engine bay on top of the lower part of the stock airbox:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2419374634
Old Jun 14, 2003 | 07:38 AM
Jime's Avatar
Yup, thats the one. It will work in either mode. I use mine in hybrid mode but I can put the extra pipe on and use it as a CAI in the fender well too.
I also have another length of pipe which I use to extend the filter to the front of the car behind the headlight which I remove for racing. I also had to relocate the battery a bit to get it to fit.
Old Jun 14, 2003 | 08:03 AM
D1NOnly34's Avatar
Wow thats looks good, so I should get than one then?
Old Jun 14, 2003 | 08:37 AM
Jime's Avatar
That is just a modified BOMZ type, I got another piece of 3" aluminum and used it for an extension. Thats what good about the BOMZ you have some options.
Old Jun 16, 2003 | 12:48 AM
hoodedmunkee's Avatar
whats the difference with a hybrid from a cai and short ram?im trying to get an appropriate set up too.
Old Jun 16, 2003 | 03:47 AM
Max Noob's Avatar
cai- your extra 6-10 hp are in low and mid range
hybrid- your extra hp is gained in mid range
pop charger(i think this is the short ram you are talkign about)- top end hp gains.. peopel with auto report slight loss of power in low end.
lowpost99
22
Sep 2, 2015 04:38 PM
raffivegas
Aug 23, 2015 09:54 PM
220k+ A32
Aug 17, 2015 03:57 PM
doobadoo
Aug 15, 2015 06:43 PM
