keyless Entry Question
Old Jun 14, 2003 | 06:52 PM
96white's Avatar
Hey , I have a 97 GXE. What do I have to do to get Factory keyless entry. I have power locks and everything, but no remote? Could i just buy a remote and have it programed?
Please help !!!!!
Old Jun 14, 2003 | 08:10 PM
98MaxVancouver's Avatar
Provided your Max came with the GXE Security and Convience Package, then you should be able to buy a remote from the dealer or off of eBay.
Page 6 of the FAQ just near the bottom has instructions on how to program the remote.
Cheers,
Old Jun 14, 2003 | 08:56 PM
klymkow's Avatar
Cheers,
Easy way to tell is if you have the security light on the left side of the steering wheel, next to the cruise control on/off switch.
Tim
Old Jun 14, 2003 | 10:02 PM
96white's Avatar
nope, nothing. What do i have to do now?
Old Jun 14, 2003 | 11:28 PM
TylerBorg's Avatar
buy an alarm
Old Jun 14, 2003 | 11:30 PM
Maxima95Tuner
Dont buy a factory alarm, upgrade to something better. You won't be sorry.
Old Jun 15, 2003 | 08:33 AM
ORBRIT's Avatar
or if you just want keyless entry by an Omega keyless entry unit on ebay for $45 or so (includes shipping and the double pulse module) and install it yourself - it's a fairly simple process - I have a 97GXE with no S & C package - but now I have keyless entry!
They will ask you for your make/model/year of car and send you a wiring diagram and also tell you that you need a duoble pulse module - Our locks work with a double negative pulse.
I installed the receiver unit in the driver door - and tapped into all the wires right there from the window/lock switch console.
These are the directions for a 1997 GXE:
The parts are:
Programmable output unit
4 wire harness
AU-DP double pulse wiring harness
Remove the Window switch/door lock switch unit from the driver door.
Unplug the wiring harness.
Cut the White/Pink(purple) wire, the Black wire, the Light green/red wire and the green/yellow wire.
The red wire from the double pulse unit and the red wire from the standard wiring harness splice together with the White/Pink wire which is +12V always hot. Solder all these together and rejoin the white/pink wire.
The black wires from the AU-DP and the standard wiring harness should be soldered to the Black wire in the driver door.
The Blue and Brown wires from the AU-DP should be soldered to the Green/Yellow wire.
The Green wire from the AU-DP should be soldered to the Lt. Green/Red wire.
Insulate all cables with electrical tape.
Plug in the standard connector on the 4pin plug. Plug in the AU-DP on the 3 pin plug with the pink cable not plugged in.
To program the device, press and hold a paper clip or other long pointy item in the transmitter programming switch for 2 seconds.
Press the Unlock button on the remote. Wait for the unit to beep and flash once.
Press the Lock button on the remote. Wait for the unit t beep and flash twice.
wait 10 seconds and the unit will chirp 5 times and exit programming mode.
Plug the door lock switch back into the wiring harness.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
