Gas Pedal Responsiveness
It's connected to the throttle body (fire hydrant looking think next to the air intake). There are 2 cables, one is for the cruise control, the other for the throttle. Tighten both by pulling out the slack and retightening the bolts on the cable...
Next to the throttle body. There's two of them, one is for the cruise control and the other is your gas pedal. Just take the slack out of them, don't make them to tight or you may start to pull the throttle open which of course will jump your idle speed up.
Open engine bay. Look on top of the intake manifold. You will see two cables. One is the throttle cable one is the cruise control cable. Figure out which one is throttle and tension it a bit using the nuts on the cable.
ZuM
ZuM
Originally posted by Socrates
Which are located where exactly, if you don't mind my asking?
ZuM
ZuM
06-06-2017 02:01 PM
