o2 sensor question
Old Jun 17, 2003 | 08:25 PM
viet_racer22's Avatar
o2 sensor question
My cel keeps on going off after resetting it about 3 times so I know its bad. After searching about oxygen sensors I found a few websites people posted and they sell them for about $65 shipped (oxygensensors.com). I'm not much of a internet shopper so I called around today and a local shop sells Bosch UNIVERSAL oxygen sensors for the same price. The difference is that I will have to slice the wires onto the stock o2 sensors. Which do you think I should buy? The regular Bosch sensors cost $90 or so. Thanks.
Old Jun 18, 2003 | 11:27 AM
bump
Old Jun 18, 2003 | 01:10 PM
97blackSE's Avatar
Sup man, I give you an EXTREME amount of credit for finding www.oxygensensors.com... I always tell EVERYone to use that site...It has the CHEAPEST prices you will find around! The Universal sensor is not as good as the oem deal, and you have to splice and wire it, if you buy the oem style one from oxygensensors.com, for 65 Shipped, then it is a direct replacement, unscrew old from y pipe, disconnect plug, screw in new sensor, reconnect new plug from new sensor...its extremely easy...the customer service from that site was also excellent, i had my sensor within 3 days, and it even comes with anti sieze... Hope this long ramble helps, Kyle
Old Jun 18, 2003 | 01:20 PM
lefty
I went to the site and for my 98 max, I found only one part number.
are all of our O2 sensors all the same in the front and rear?
Old Jun 18, 2003 | 01:51 PM
4thgenguy's Avatar
The 2 front O2 sensors are different the the one behind the cat. BUT when I ordered mine they called me the next day to verify which one I needed.
Old Jun 18, 2003 | 03:35 PM
95maxmadman's Avatar
yeah. they fron two are the same as each other.
There's just different lengths of wire and clips in
certain places.
Old Jun 18, 2003 | 04:15 PM
drageron's Avatar
thats a bomb *** site they do good business for 39.99 its not that hard to splice and install better then payin 80 or 90 buks plus i get about 80-100 more miles to the tank, such a good improvment oh yea it went from cali to ny in 2 days for no shipping cost how goods that
Old Jun 18, 2003 | 07:57 PM
Max96GLE's Avatar
At first when I just changed one sensor and started my car. It started shaking like crazy. I was like, What the ****! Right after I change the second 02 sensor. My car kept dying. The RPM was too low. It was like running around 300 to 400 RPM. I raised the idle rpm higher and is fine now. I reseted the ECL and a day later, it came back on again. I checked on the code and it said the front 02 is causing the problem. The code were 0303. It just came out continously. I have to go to Autozone and do one of those daily loan tools set for the 02. Hopefully, I will be able to fix it.
You need a oxygen sensor tool set to remove the engine 02 sensor. There is no way you can change it without it.
_______________
1996 Maxima GLE
Old Jun 18, 2003 | 08:45 PM
Thanks for your replies. I'm going to order my o2 sensor in a few minutes. Thanks again.
bbsitum
Sep 6, 2019 07:31 PM
220k+ A32
Sep 11, 2015 02:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
