Y-pipe install question
Old Jan 29, 2001 | 11:04 PM
nismo96max
I just got my Warp speed Y-pipe, on the two inlets, there ar holes on each (for the )2 sensor I presume). I have a 96 GXE, Do I have 2 O2 sensors? Is it going to be just a bolt on or will I have to do something else in addition?
Adam
Old Jan 30, 2001 | 12:11 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
if its the same as Stillen and Cattman Y-pipes, the 2 holes on each pipe is for the 02 sensors. You should use a special tool or a 22mm or 24mm wrench works too but im not advising you to use that cause you can strip them. Once stripped you'll have fun taking them off.
Old Jan 30, 2001 | 12:24 AM
emax02's Avatar
I just finished removing my Y- Pipe about 4hours ago,
in 15 degree weather with snow on the ground.Anyways it's a pain in the but {which was frozen solid seriosly, hehe} and can get bloody real fast.As for removing the o2 sensor I just used one of those adjustable wrenches and pushed really hard and snap....smash,yep my hand is bleading ouch,atleast I loosened it.I recomend you use a pair of work gloves to avoid smashing your hands on stuff,also you need a 14mm deep socket wrench with extensions.The 14mm Bolts are practically invisable though so I recomend spraying it real good with WD40 before you get started{which I was out of},then after getting a wrench on the bolts I used a large pipe for TQ and it made the Bolts budge finally sheesh! I have to take it off my I30 tomarrow too oh god haha.Have fun!
Old Jan 31, 2001 | 10:04 PM
plrod Black 95 SE's Avatar
why don't u disconnet the sensor electrical connection and just take the sensor off when the y pipe is off the car
JRod28
Dec 29, 2023 09:56 PM
VQ'ed
69
Aug 27, 2020 12:29 PM
Greenmaxspeed
Aug 31, 2015 09:06 PM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
