cleaning throttle body
Old Jun 19, 2003 | 11:58 PM
icheban26's Avatar
i'm goin to clean the throttle body, my question is "wat kind of spray should i use to clean it? would w40 be okay?"
n also, inside the throttle body there is a butterfly plate...can i lift that plate up to clean the plate n also clean watever is behind it?
sorry for all the question, but this is my first time doin it so i want to make sure i know wat i'm doin.
thanks
icheban26
Old Jun 20, 2003 | 12:05 AM
pjalst
Re: cleaning throttle body
thanks
icheban26
They sell "Throttle body cleaner" in auto parts stores. Use a toothbrush to clean the butterfly plate and inside the throttle body.
Old Jun 20, 2003 | 12:12 AM
KsuMax's Avatar
Cheesing away...
Throttle body cleaner, at advanced auto parts.
Old Jun 20, 2003 | 12:29 AM
icheban26's Avatar
Re: Re: cleaning throttle body
thanks for the advice.
now wish me luck
icheban26
Old Jun 20, 2003 | 12:41 AM
Dev's Avatar
Dev
thanks
icheban26
DO NOT use WD-40
that is oil/grease...you want to use a degreaser
look to the left of the tb opening...where the throttle cables connect...just push that and it'll open the butterfly up...then clean inside with a rag
Old Jun 20, 2003 | 02:56 AM
Max Noob's Avatar
use carb or throttble body cleaner at local car part store.. u can move the butterfly plate around.. clean all around it and dig as far in as you can with tooth brush cleaning brush ect. then use somethign to keep your butterfly valve open and let it dry for like an hour..(i sprayed in over half a can it left a pool in there..) then put everythigback and start your car. some people will telll you to start your car witha ll that tb cleaner stuff in there but i dont feel safe about letting that stuff burn through out my engine. think it can damage something.
Old Jun 20, 2003 | 07:48 AM
time2reup's Avatar
be mindfull of the nozzle on the cleaner...it will shoot off and go down into your precious little VQ...
also a good writeup on motorvate.com
Old Jun 20, 2003 | 08:40 AM
icheban26's Avatar
gd stuff everyone
i will try to do this once the weather get better...i only wish a had a garage.
icheban26
Old Jun 20, 2003 | 09:19 AM
pjalst
gd stuff everyone
icheban26
If it hasn't been cleaned in a while, you will defenitely notice the difference.
Old Jun 20, 2003 | 10:08 AM
Dev's Avatar
Dev
gd stuff everyone
icheban26
like someone mentioned...be careful of that nozzle/straw
it shoots off sometimes
after i cleaned it, i just started the car up...and let the fluid go through the rest of the TB and combustion chamber...
Old Jun 20, 2003 | 10:13 AM
icheban26's Avatar
thanks for the link...now my only question is...i have the oem air filter box...how do i go about takin that off before i can follow that write-up???
thanks
icheban26
Old Jun 20, 2003 | 02:20 PM
Max Noob's Avatar
remove clips from the upper airbox.. remove teh hose clamp that connects the tb to the air intake piping. remove the 3 breather hoses that connect the the big plastic thing on the stock intake.. disconnect the 2 plug from the maf... then pull the whole thing off as 1 peice..this is good casue it gives you alot of room to work, and its easy to out back together.. hope this helps..
Old Jun 20, 2003 | 05:23 PM
ZeRo MaX's Avatar
i still need to clean my throttle body... so all this information is gonna be helpful... just one problem... is it really easy as everyone says it is... i'm not too much of a mechanic or anythin'....
Old Jun 20, 2003 | 07:34 PM
Max Noob's Avatar
its cake man..if you put your nwt intake in yourself, this will be cake
Old Jun 20, 2003 | 07:39 PM
icheban26's Avatar
i have no clue wat u just said ...j/k, but yeah...hopefully it'll start to make sense when the airbox is in front of me.
thanks
icheban26
Old Jun 20, 2003 | 08:11 PM
Max Noob's Avatar
ahha.. when u look at it.it will come to you..just rememebr to use come common snese and dont take off more than you need..have fun man.. i got a wierd hissing sound after i cleaned my TB..souds like its comming fro near the injectors..anyoen else got that or know whats up?
Old Jun 20, 2003 | 08:38 PM
drjohnnyfever's Avatar
There is a nice write up w/ pics on throttle body cleaning at http://www.motorvate.ca
Old Jun 20, 2003 | 10:22 PM
icheban26's Avatar
that is probably the last thing i want to hear
another question...the silver clamp in the pic...do i just use force to slide it over or is there a better way to remove/loosen the clamp??? cuz i saw that clamp in my engine n its clamped pretty tight to the hose.
tia
icheban26
Old Jun 21, 2003 | 03:56 AM
pjalst
thanks
icheban26
The first thing you need to do is get a Haynes Manual for yor car, It's very helpful and has detail pics of simple maintenance you can do for your car. The first qustion anyone should ask here is, Where do I get a HAynes Manual?
Old Jun 21, 2003 | 10:10 AM
Speebs's Avatar
I aim to misbehave.
tia
icheban26
Just use a pair of pliers to squeeze the tabs at the top of the clamps. That will loosen them and you can slide them down the hoses (don't take them off... you're likely to lose them)
Old Jun 23, 2003 | 01:45 PM
icheban26's Avatar
i finally got around cleaning my throttle body n changin the fuel filter. overall, the task was fairly simple...except that changin the fuel filter was kinda messy. so, i just want to thanks everyone who contributed to this thread n gave me adivce.
now i just hope i get better gas mileage than my current stingy 280miles/tank
thanks again!!!
icheban26
Old Jun 23, 2003 | 02:24 PM
Taxvictim's Avatar
How did you change the fuel filter? I tried that and couldn't get my hands into any decent position to get the screws. When I finally got a phillips head screwdriver onto the top screw, it wouldn't budge.
Assuming you did all the steps to shut down the fuel pump and depressurize the system, did you take the filter out of the bracket before you undid the screws? I can't even figure out how the dealer's mechanic would do it.
Old Jun 23, 2003 | 02:42 PM
icheban26's Avatar
yes, pull the fuel filter out from the bracket...that way, at least u can have better access to the screws. but i would recommend u takin the whole OEM airbox, MAF piece out first...that way u can reach the fuel filter with no problem, n also cleanin the throttle body at the same time.
icheban 26
Old Jun 23, 2003 | 02:50 PM
Taxvictim's Avatar
Ah, hah! So, you reach the lower screw from the side instead of coming down from the top. Sounds like I have an interesting evening in store for me. Thanks!
Old Jun 23, 2003 | 07:23 PM
icheban26's Avatar
yeah, its nearly impossible to reach the fuel filter w/out removin air box n MAF piece. so thats y i follow the instruction at www.motorvate.ca for cleanin the throttle body (which requires u to remove the air box n MAF) n at the same time changin the fuel filter.
icheban26
Old Jun 24, 2003 | 10:14 AM
joew's Avatar
Changing the fuel filter and the PCV valve is a real b--ch. No need to remove anything but your fstb. You can easily remove canister from the upper hose and the lower hose. It is more difficult to unscrew from the canister because to tends to move.
Old Jun 24, 2003 | 11:07 AM
sblax2000's Avatar
I have next to no mechanical skills but didn't have to remove the FSTB bar for the fuel filter replacement, what about the PCV valve, how easy is that to replace?
Old Jun 24, 2003 | 01:17 PM
joew's Avatar
it's a b--ch to replace but anyone can do it.
Old Jun 24, 2003 | 01:43 PM
sblax2000's Avatar
where is it located?
Old Jun 24, 2003 | 09:32 PM
joew's Avatar
here it is, just go down the list. it's from the faq.
http://forums.maxima.org/showthread....5&pagenumber=6
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
