Weight Reduction...Qs and TIPS
Ok so I am thinking about doing some weight reduction to my Max. I have some questions first:
1. What the heck is the black plastic on my hood for? Seems like a waste. That was the first thing I was going to take off.
2. You know the metal shields that are around the brake discs? My friend told me they are dead weight and they dont do anything. He thought they might weigh up to 10 lbs each. What are they for? Do I need them?
3. I just recently cleared out my tailights and found some pretty thick foam lining behind the stuff that lines my trunk...why would I need that?
4. I was told there is all kinds of foam padding underneath my carpeting...is someone laying down there so that it has to be comfortable? Why would I need that?
5. I have taken my rear bench out before and noticed some sheet metal that doesnt seem to be needed in the backrest. Will removing this affect my passenger's safety? I was thinking sheet metal probably won't have any effect on anything...
So basically any imput anyone has is helpful to me. I have never tried a project like this on a car so I need to relay ideas back and forth so that I can know if I am doing anything wrong. This guy I met removed 300lbs from his E36 M3 and on a stock motor he was running about 13.5-6 according to him. They normally run about 14.0 stock. I dont think that I will get that crazy about removing weight from my car but I'd like to give it a try with some stuff.
The only thing that worries me is my Dad's consistent thought that everything I do to my car "It was not made for." So therefore he thinks that taking something off is stupid because "If it is on the car, it is there for a reason." For everything that I have listed so far I cannot see the reason that it is part of my car except maybe sound defenning(wow i dont know how to spell that). Besides that I dont see how any of these reductions would hurt my car. Opinions and other helpful ideas on weight reduction would be a big help. THANKS.
you should leave the caliper shields behind the brakes. i don't see how those would weigh 10lbs apiece.
i wouldn't remove the padding under the carpet either. the carpet won't fit right after.
i also wouldn't remove any metal from the structure of your car...
wow...... that was helpful
Personally, I wouldn't go cutting out pieces of sheet metal, it's probably there to make the car more rigid. If you havent already done so, taking out the spare tire and jack will save a pretty significant amount of weight, I wouldn't really reccomend it though if you drive long distances daily. If you have subs in the trunk, get rid of those too.
i would look around for some stock 15in wheels to put on for track use. You could drop some weight there.
I think you need to make up your mind about your car. If you intend to keep it as a daily driver, I wouldn't remove anything (though the suggestion of lighter wheels was good). If you want a little weight reduction at the track, pull your spare + jack out, and floormats. If you want to make it like a race machine, then by all means, pull out the carpets, padding, rear seat, passenger seat, dash, trim, etc. I wouldn't go around cutting sheet metal off my car in any case though. The specific piece you mentioned is almost certainly there for chassis rigidity. I like driving fast too, but I'm not about to gut my car for it.
GMT
PS- the padding under the carpets is probably noise insulation. Expect your interior to be loud loud loud if you remove it.
GMT
GMT
GMT
If my car being loud is the only side effect I dont mind. I wasnt talking about cutting any metal. The piece I was talking about bolts on.
Originally posted by plurco
how about the metal bumpers behind the bumper covers? they should be at least 40 lbs a peice.
AHHHHHHHHHHHHH
Going down the list:
-I have the Y pipe.
-I have the UDP.
-I have the catback.
-Plate under steering wheel? Whats it for?
-Support bar for glove box? Whats that do?
-Plate behind back seat...i think thats what i was talking about before.
-Sound deadening under hood, yup I thoughta that.
-Handles on ceiling. haha. i think my passengers need them.
-Aftermarket cat..probably doing it soon.
-Lighter rims...looking into it.
-Racing seats...i wanna keep a stock look.
-Ground control coilovers??? didnt realize they weighed less...why is that? WIll a KYB/AGX and Eibach combo help me lose weight as well? cause thats what I want to do.
-Hood-thinking about it
-Fast brakes kit? where is this available?
-Back seat is 30lbs...DAMN...it didnt feel like it weighed that much.
So......so far it seems out of that list I could take out about 15lbs for free and then any other weight savings costs $$$$$$$$$$$$. GREAT! So good weight reduction seems to be through Hood, Ground controls(still wondering if my aftermarket AGX/Eibach combo will have the same effect), the fastbrakes kit, and racing seats(which I am not wild about doing). This seems like the only effective things to do to save weight.....
No sarcasm, I think Sprint did this. Sure it is not as safe, but it is lighter.
I think the only thing right now that I might do, which doesnt cost money,(cause I dont think that I could be effective without going crazy on removing all my lining and sheet metal that is prolly supposed to be there for some reason) is to remove the sound deadening thing on the hood. I think it would look better and I wouldnt mind a little extra sound coming from the engine compartment. hehe.
Originally posted by luckee2bhere
hmmm. my fault. definitely doesnt sound safe. at least not for the street.
Re: Weight Reduction...Qs and TIPS
2. You know the metal shields that are around the brake discs? What are they for? Do I need them?
-hype
Originally posted by MaxPursuit
If you're really that serious you should probably drop the AC. You'll be hotter but lighter.
all that you listed here is an exercise in futility. Every single thing added together that you posted probably would amount to 30lbs. Or you can get some wheels and a cf hood and a lightweight race battery and drop about 70lbs. not to mention all that crap will make your car totally unbearable to drive or ride in. btw those brake shields weigh about 1 lb a piece.
Here is what I have done, last weighin I was at 2750.
Everything in the trunk
Sound deadening under carpet
Tie down hooks under car
Seats $125 for both with covers and weigh around 11 lbs each
Battery, 400 cca from a starter assist pack, 11 lbs
Front and rear bumper supports
K1 15x7 with slick on front
Millenia 15x6 with 195x75x15's on rear pumped to 65 psi
Take a pee and a crap before you race and don't put your full weight down on the seat.
Planning on taking off the dust shields for the brakes next week.
Also going to take the 97 SE to the scales this week to see what it is in comparison.
its without him in the car....says in the timeslip forum i think
i think i am going to pretty much nix this losing weight idea of mine and just fold my side view mirrors in. that should help. hehe.
sdotcarter
09-02-2015 09:53 PM
Justin Kroll
09-02-2015 11:06 AM
