ok better description of my starting problem please help>>
ok 95 maxima gxe. the car turns over normal. Starter sounds fine. while the car is turning over it sometimes doesn't seem to fire. it sounds like it is trying to start once and a while catching a little but not enought to start. if i press the accelerator down just a little while turning it over the car will start. let e know if you have any ideas
thanks
thanks
Hmm insufficient fuel or air. It's hard to diagnose the problem. Your car isn't throwing a code is it? If it isn't than it's hard to say it's a sensor like TPS or anything. Fuel filter, injectors, spark plugs, might be having a problem. Could be somewhere in firing, fuel delivery, or oxygen/throttle sensors.
thanks
thanks
When your foot is off the gas, the throttle blade is completely closed. That means all the air which gets to the engine is supplied by the Idle Air Control Valve - Auxiliary Air Valve.
I suggest you test the IACV-AAC and the Throttle Position Sensor.
Daniel B is right actually. However, I doubt it's the TPS. One can always tell when that sensor is going. The car will tend to jolt at lower RPMs. If he is ONLY having a problem starting than I doubt it's the TPS.
Originally posted by Mark's Max
The starter on the 95 is terrible. I have a 95 GLE and I have the same problem. I think it is the starter, not the fuel filter or any thing else as a matter of fact. nissan wants 500 ti fix it
bs
bs
This is not to say the '95 starter motors are wonderful. If you have a slow-crank or no-crank problem, the starter motor could be at fault. However, battery or cable problems will also produce the same symptoms.
Maxima30
Sep 7, 2015 06:13 PM
sdotcarter
Sep 2, 2015 09:53 PM
