KS code a false reading for this problem?
Old Jun 23, 2003 | 12:36 PM
AdMax98's Avatar
I just had the codes 0304(Knock Sensor) and 0705(EVAP Control System) come up on an ECU check. I remember I had a knock sensor code come up a while back when I had an O2 sensor problem. Is this another false knock sensor reading?
Also, what does the EVAP code mean exactly? I'd like to fix the problem on my own since I dont want to shell out $$$ to the dealer for an easy repair.
Any help would be greatly appreciated.
Thanks,
Old Jun 23, 2003 | 04:29 PM
D1NOnly34's Avatar
Chances are that if you check/fix the problem with the EVAP system, the KS code will go away. If you have a Haynes manual you can find out whats your problem. How is your car running? Differently? Any symptoms that have changed due to the code?
Old Jun 23, 2003 | 04:36 PM
AdMax98's Avatar
Car seems to be running as per usual. The code came up when I was driving for a long time on a hot day. I've reset the ECU since, and the problem still comes back even though the weather has become milder.
I guess I'll have to get myself a Haynes manual...unless someone would be kind enough to look up what part I need to fix/replace.
Edit: Finally got search to work. Seems like it could be just an EVAP control valve problem....easy fix!
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
