Rear BRAKE **** UP
Old 06-24-2003, 09:57 PM
maximusx20's Avatar
Rear BRAKE **** UP
me and my friend did my rear Brakes on a 98 se and on one of them we commpressed the piston with a clam insead of twisting it in...when i drove it it make a squeling sound and got the wheel extremly hot...the other side we screwed it in my mistake since the whole piston poped out and is fine..wee did not realize the diffrence cause only have done front brakes..my question is the caliper destroyed or can i take the piston out and twist it in the right way.......
maximusx20 is offline
Old 06-24-2003, 10:29 PM
maximusx20's Avatar
BUMP>
Old 06-24-2003, 10:35 PM
Max Noob's Avatar
good luck on this one..i duno.. free bump though
Max Noob is offline
Old 06-25-2003, 05:51 AM
njmaxseltd's Avatar
You most likely distroyed that caliper.
njmaxseltd is offline
Old 06-25-2003, 06:51 AM
maximusx20's Avatar
bump
Old 06-25-2003, 07:21 AM
maximusx20's Avatar
does some one have link on changing the calipers..on a max or anything similar>....
Old 06-25-2003, 11:10 AM
MaximaMoJo's Avatar
Get a Haynes Manual and save money on repairs.
MaximaMoJo is offline
Old 06-25-2003, 11:17 AM
Pappa Grande's Avatar
Get a Haynes Manual. It doesn't look hard at all. You almost removed the caliper when you changed the rear brake. The only other line you would need to remove is the brake line and one additional caliper bolt. Then you would need to bleed the brakes.
Pappa Grande is offline
mvm062
11-30-2020 09:00 AM
AcuraLegend
10-17-2016 08:47 PM
AcuraLegend
09-22-2015 04:22 PM
homeyclaus
09-03-2015 06:15 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: Rear BRAKE **** UP
