Partial throttle hesitation?
Old Jun 25, 2003 | 01:51 PM
DougsfastZ's Avatar
All Black Max
This is hard to explain but under partial throttle, lets say 30% in any gear (mainly happens in second and third), while holding the throttle steady just doesn't pull smooth. It doesn't buck or anything but it is noticable. It's almost like I'm barely feathering the throttle when I'm really holding it steady.
Any ideas? Pulling timing maybe? MAF sensor on its way out?
I also happens at full throttle, but it is not as significant.
Thanks,
Doug D
Old Jun 25, 2003 | 01:53 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
check yer air filter and clean throttle body.....i had the smae problem last week until i did that.
Old Jun 25, 2003 | 02:26 PM
slizan99's Avatar
have you checked your ecu for codes? thats what mine feels like and i have a bad knock sensor.
Old Jun 25, 2003 | 03:02 PM
nismos14's Avatar
§è~® f®ÈÄk
if cleaning the tb and air filter dont pan out try the fuel filter
Old Jun 25, 2003 | 04:24 PM
TooMAX's Avatar
And if you need more ideas if the ECU doesn't throw any error codest, try checking the knock sensor and cleaning the EGR system.
Old Jun 26, 2003 | 10:23 AM
DougsfastZ's Avatar
All Black Max
New fuel filter, cleaned the TB and air filter. EGR system was cleaned when the MEVI was installed. I did replace the knock sensor about 8 months ago, could it have gone bad already?
Does anyone have the instructions to bypass it as a troubleshooting step?
Thanks for all the suggestions!
Doug D
Old Jun 26, 2003 | 11:37 PM
on_alert's Avatar
Originally posted by DougsfastZ
EGR system
Doug D
Yeah, what he said! Anyone have it?
Old Jun 27, 2003 | 05:32 PM
ZeRo MaX's Avatar
check the throttle cable.. i remember someone sayin' tightenin' it will make it better.. it could be loose...
Old Jun 27, 2003 | 05:35 PM
RichMax's Avatar
Boosted like Snipes tax refund
Sounds like when you check ur ECU you will get an 04 03 (Throttle Position Sensor) fault. Apparently I need to learn more about mine cause its the only code that keeps popping up all the times I've reset it over the past few months in about 100 miles of driving for the last couple of days (half a damn tank- I am SOO MADDD!)
msellas
Sep 23, 2015 09:16 PM
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
bumpypickle
Sep 20, 2015 08:22 AM
Bonka
Sep 14, 2015 11:18 PM
