Changing fuel filter
Old Jun 25, 2003 | 08:29 PM
Maximum96's Avatar
I changed my fuel filter a couple months ago. i did not pull the fuse or anything. did i need to pull the fuse, when do u pull it, when the car is on or off?? did i mess up the pressure in the fuel system or something??
Old Jun 25, 2003 | 08:33 PM
patel_anu's Avatar
Re: Changing fuel filter
yeah your car is fine, the only reason you take the fuse out is to relieve the pressure so when you take the fuel filter off, not as much fuel will go shooting everywhere, and your supposed to take the fuse out first and than crank it a couple times until your car doesn't start
Old Jun 25, 2003 | 08:35 PM
z32drifter's Avatar
don't worry about it....they recommend pulling the fuse and running the eng until the car stops to keep you from spraying yourself with gas when you disconnect the fuel lines.....so if the filter is new and the car runs with no leaks....good job later
JoshG
51
Sep 21, 2015 10:41 PM
iamute
Sep 20, 2015 05:22 PM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
sdotcarter
Sep 2, 2015 09:53 PM
