Anyone with a 99.5+ Max? Help!
Old Jun 26, 2003 | 05:21 AM
RichMax's Avatar
Boosted like Snipes tax refund
Here is what I can tell you for certain:
Ram-air intake has been installed for 1 1/2 weeks.
Gas Mileage, which was already not too good (300 miles/tank for 80%city 20% highway driving, occasional racing red light to red light )
is now a bit worse (280 miles/tank, same conditions) I would have figured the ECU would have adjusted to the increased air flow by now. However, I am on my second tank with the intake and mileage is looking to be about the same horrible 280 miles/tank. I DO get hesitation.
Among my recent codes:
right front heated O2 sensor which I cleared (has not appeared again)
Cylinder 6 misfire (cleared, has not appeared again)
14 06 (Undefined)
Knock sensor
All the above codes have been cleared.
Betond that, there is definetly something in my engine bay not shown in any of the Haynes manuals, (or in any of your own pics of your own engine bays, for that matter, including the motorvate.ca write-up) Again, it is a small, tennis ball-sized object connected to a mechanism which moves a lot like the trottle opener under the hood. It's definitely there, and I haven't seen it on any of you guys' photos. It blocks my view of the knock sensor, and all physical access (Unless you have a pipe cleaner and are satisfied with touching something you can't see). I'm loooking for someone with a 99.5+ Max- they may know what I'm talking about.
Old Jun 26, 2003 | 06:03 AM
njmaxseltd's Avatar
That object your looking at is part of the Swich Valves in your intake manifold. The vacuum actuator and linkage sits beside the intake. No other 4th gen has this setup. They operate when the car is cold by closing slightly to create more turbulance inside the intake manifold which is to help stir up and mix the richer air/fuel intake for better burn. We also have more o2 sensors and a different ECU then other 99 models.
It does completely block the KS even from view. I'm sure it's going to be a nightmare getting that sucker changed when and if it ever fails.
Old Jun 26, 2003 | 07:16 AM
maxhead's Avatar
Can that switch valve go bad? If it gets stuck (on), will it cause me to lose power when it's hot because it's making the air more turbulent? I'm losing power and can't figure out why. Maybe that's it.
Old Jun 26, 2003 | 07:41 AM
njmaxseltd's Avatar
They open up after your car is all warmed up. You'd get a CEL light if the system failed.
Old Jun 26, 2003 | 08:35 AM
Joeycurl's Avatar
Try to go through the install again and check all the hoses. Use the process of elimation, and you'll find the problem. When was your last tune up?
Old Jun 26, 2003 | 09:55 AM
RichMax's Avatar
JerseyMax, thanks for your help. Any ideas on how to remove and replace the switch valves/vacuum actuator/linkage?
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
