AC turning off and on. While taking off briskly with
Old Jun 26, 2003 | 01:36 PM
stjohnr's Avatar
AC on, the system would turn off and on
continously.Anyone had the same problem and if so, what was the fix for it.
Thanks in advance,
john
Old Jun 26, 2003 | 04:20 PM
Show Maxima's Avatar
Man we are in the same boat, I am having this problem too.... the damn clutch just goes click, click, click, click... and so on.... it gets on my nerves, and then sometimes, it cuts off completely, i wait for a couple of seconds turn it on, and its as good as goldy....????
Old Jun 26, 2003 | 04:37 PM
Nismo's Avatar
refrigerant is probably getting too low and is tripping the short cycle switch if we have one
Old Jun 26, 2003 | 04:44 PM
gtr_rider's Avatar
192.168.1.1
Maybe you need to give your A/c blower a friendly tap. Its right behind the Glove box you can feel it.
Old Jun 26, 2003 | 05:08 PM
Miasma's Avatar
there is a three way pressure switch on top of the drier which is under the battery/relay unit on the drivers side behind the headlight. it will turn the compressor off if there is not enough pressure to keep it safe.
Old Jun 26, 2003 | 07:24 PM
xHypex's Avatar
While taking off briskly with AC on, the system would turn off and on
Sounds like a vacuum problem to me. The car's vacuum is used to route the HVAC air through the system to the right vents. My moms Volvo has this problem, and whenever you go above 15% throttle the A/C cuts out until you back off on the throttle some (thus creating vacuum).
-hype
Old Jun 27, 2003 | 08:32 PM
stjohnr's Avatar
Thanks to alll for your comments. I took the car
to the dealer as it was malfunctioning. It turned out that the refrigerant was way too low and there is a safety switch on the compressor. It has been working since Thursday, this is good because the
Bay Area has been very hot.
-hype
Old Jun 28, 2003 | 02:54 AM
pocketrocket's Avatar
Well, it's fixed ... but it could be too high as well. My car's that way now. I'll have to borrow an HVAC gauge from work and check the FSM.
http://forums.maxima.org/showthread....hreadid=226644
captchaos
Mar 15, 2016 12:18 PM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
trungg86
Sep 4, 2015 04:58 AM
