tranny drain
Old Jun 29, 2003 | 06:54 PM
charliemax's Avatar
tranny drain
is it better to drain the tranny (5spd) from the gear indicator switch or from the drain plug? motorvate said to drain from the switch, but i was looking at the switch and it seemed to be higher than the drain plug. which will drain out more fluid, and what is the nut size for the drain plug?
thanks
charlie
Old Jun 29, 2003 | 07:55 PM
Scruit's Avatar
U wanna try me young boy?
The sensor will drain QUICKLY - like the whole tranny in about 30 seconds. Be ready for it - nearly 2 gallons.
The drain plug is a lot slower. Also, you'll never drain it fully - if you're removing to rebuild it you'll need a drip pan on your workbench when you crack it in half.
Old Jun 30, 2003 | 12:46 PM
slfalco's Avatar
2 gallons? I am about to change my fluid this weekend, and my Haynes manual said 9-10 pints, which is 5 qts or 1.25 gallons. Or am I missing something? I hope not, I ordered up 5 qts of Redline MT90, just showed up!
Old Jun 30, 2003 | 01:17 PM
Scruit's Avatar
You're prolly right - I know I used about 1/3 of my 5gal drum of GL4. If ur haynes say 9-10 then they're prolly right.
How are you going to fill it? The easiest way I found was to get a funnel with a FAT flexible section and hang the funnel fron the driver's wheel spring with the tuber bent around into the filler hole. I also covered the driver's knuckle/hub assembly with a garbage bag in case I spilled oil on it. Have some brake cleaner handy and rinse the brake disk off before you puty it back together just to be safe.
Old Jun 30, 2003 | 01:37 PM
slfalco's Avatar
To fill it, I ordered a cool fluid evacuator/dispenser thing I saw in my Griot's Garage catalog. Pricey, but what the hell, can't have too many tools and such... I am hoping to use this thing to 'inject' the new fluid 1 qt at a time...
griots catalog
Forge277
Jun 13, 2016 09:26 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
markevans999
Sep 10, 2015 04:29 PM
pktaske
Sep 4, 2015 08:40 AM
