Track result for new intake prototype are in!!! WOW!!
ok here is the deal, I am sure most of you have seen the thread about a new intake I am designing, if not here it is. https://maxima.org/forums/showthread...hreadid=227804
So i went to the track today, and compared the data to my last trip.
Here are the results. I will list specs for my last trip first then my trip today.
temp 75
humidity +/- 35%
elevation 120'
time 7:00 PM
60' 2.30
1/8 mile 9.55@74.4
1/4 mile 14.82@93.8
today
temp 92
humidity +/-65%
elevation 500'
Time 2:30 PM
60' 2.25
1/8 mile 9.53@74.69
1/4 mile 14.75@94.19
the last time at the track I ran with my JWT popcharger, everything else is identical on the car.
I know to some of you this does not sound too dramatic, but for the more seasoned track goers, this should seem huge. I had the temp. humidity and elevation working against me. If the conditions were exactly the same I KNOW i could have gotten another tenth off my time at least. This has given me all the info I needed to put further research into this product. I am now looking for a bone stock maxima in alabama to be fitted with the first true prototype, which will include a fiberglass heatsheidl/collector, and a much more refned
look than my original version.
All input is appreciated.
temp 75
humidity +/- 35%
elevation 120'
time 7:00 PM
60' 2.30
1/8 mile 9.55@74.4
1/4 mile 14.82@93.8
today
temp 92
humidity +/-65%
elevation 500'
Time 2:30 PM
60' 2.25
1/8 mile 9.53@74.69
it also draws air from the fender well when the headlight is in place. The position gives it the biggest benifits. After this one has been developed I have plans to develope a cool air intake that retains factory filter placement. However it will not be as effective, but should still be better than the JWT intake. Keep in mind, I plan on this product costing only about $50 more than the JWT popchargeer as well. and that includes, filter, heat sheild/ collector, MAF adapter, midpipe, battery relocation kit, and all couplings and hardware. I hate to sound too optimistic, but this could rival the budget Y pipe as biggest bang for the buck product for a stock maxima.
Originally posted by plurco
I believe MZMTG was like four tenths off his normal times with the poor track conditions today.
yes it is drawing air from elsewhere.I am not saying that the filter is sealed from the engine compartment air, but I would say under normal road use.(headlight in) there would be less than 20 air intake from the engine compartment, with the majority being in the form of flowing exterior air.
i am traveling to alabama pretty soon, im stock, i would be willing to be ur tester if ud like, e-mail me and let me know todavis@memphis.edu
Originally posted by mzmtg
Yes, the conditions today were horrible. My best is 15.1 with just an intake. I've since added a Ypipe and couldnt do better than 15.6 today. For Davy to beat his record, the intake must me effective.
It was deadly hot.
It was deadly hot.
Originally posted by 96sleeper
automagics hate heat alot worse than 5spds too, thats part of the reason I didn't go yesterday, my car loses about 3 tenths in the hot weather like that. Ben...is your car only fast when its 20F?
I was so down on power, I couldn't even get the tires to spin, even a little.
My only question is how fast do you run with just a JWT/hybrid. When you pull the headlight you get considerably more air regardless of which intake you have. Jime's intake is pretty cool as well, but I'm not really seeing enough gains to warrant turning the battery 90*, removing the headlight, and spending more money on intake piping.
-hype
-hype
good job man! that really makes a big difference. so your headlight was in place when you ran?
Is that setup louder than other intakes?
Is there more risk for that intake to suck up water?
Just remember when you get rich don't forget about the org!
It's not any louder than any other intake.
It won't suck up water.
Re: Track result for new intake prototype are in!!! WOW!!
Great job with that intake. Most people dont see it but with those weather conditions it really made a difference. Not to criticize but what if you put an inverted filter in there? An inverted one would receive air just like that one and head on into the filter as well. It may not be a day and night difference but it might draw in a little more air. Just my .02
Re: Re: Track result for new intake prototype are in!!! WOW!!
Re: Re: Re: Track result for new intake prototype are in!!! WOW!!
Keep us posted, I've been wanting to relocate my battery and remove the headlight for drag racing for some time now. Just haven't gotten around to doing it. How long does the removal of the headlight alone take. I haven't looked at it close enough to have any idea.
Re: Re: Re: Re: Track result for new intake prototype are in!!! WOW!!
mkaresh
03-12-2018 06:48 PM
