Need help with strut replacement
Old Jun 30, 2003 | 02:17 PM
JBza's Avatar
I seem to have run into a bit of a problem while replacing my struts. I have the spring compressed and I tried to loosten the top nut that holds the mount and bushings to the spring. When I went to turn the nut, the top portion that is used to keep the strut from turning broke off in the cresent wrench that I was using. I need to somehow keep the strut from turning so I can remove the top nut. Any help would be much appreciated.
Old Jun 30, 2003 | 02:28 PM
JBza's Avatar
here is a pic
Old Jun 30, 2003 | 03:27 PM
Jatan's Avatar
The picture doesn't show
Old Jun 30, 2003 | 04:00 PM
Flava_24/7's Avatar
Boosted Panda
Re: Need help with strut replacement
Cant see your pic but the only thing i can think of is to use some vise grips to grab onto the piston through the spring since your replacing it any ways. I had to do this before.
Old Jun 30, 2003 | 06:23 PM
klymkow's Avatar
Put a long screwdriver between two of the studs on the strut mount. Hold the screwdriver/mount while you loosen the nut. Shouls break loose with no problem.
I loosen the nut while still mounted in the car. Makes it a little easier later on.
Tim
Old Jun 30, 2003 | 07:54 PM
JBza's Avatar
Thanks for the replies. I ended up taking a torch to it and it came right off. I ruined one of the bushings but that was no big deal.
kingw323
20
Oct 21, 2015 08:36 AM
95Maxi
35
Sep 2, 2015 10:37 AM
seesole
Aug 26, 2015 11:22 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
