how do i lock the flywheel?
dang, i was hoping this would be having to do with unbolting the fhywheel or something.
put the car in 3rd-5th gear. the lower the gear, the harder to move, just make sure one wheel is on the ground or have someone step on the brakes.
MrGone
MrGone
Originally posted by aznsap
i have an auto..... i dont' think putting it into gear works. i tried it. or do i have to start it and put it into gear and shut my engine off?
If you look at the lower portion of the transmission from the right side of the car... (I'm doing my best from memory.) Right by the support beam that runs under the motor, there is a little plate with two bolts holding it to the motor. (I think it's inbetween the beam and the transmission.) If you remove those two bolts to remove the plate, you can get to the drive plate. If you can stick something in the teeth of the drive plate safely, that will lock the motor from turning.
James92SE
142
01-02-2024 09:23 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
