Need help! Auto trans fluid in 96 Max
Old Jul 1, 2003 | 10:52 AM
Remington's Avatar
Both dealers I called said I needed to use Nissan trans fluid. The Haynes manual says Nissan-Matic "D" auto trans fluid. Problem is that it costs $5.32 from the dealer. I have right at 100k miles so I see no point in switching to synthetic. A post in the "Maintainence" forum suggested Mobil 1 ATF but didn't recommend any conventional trans fluids. Do the auto parts stores sell any fluid compatible with the Nissan trans?
Old Jul 1, 2003 | 11:00 AM
Jeff92se's Avatar
I'm needing a caw
What's up Mr. Steele!
Check this, it might help. As long as it meets the spec I believe you can use whatever. Lots of guys here are using synthetics also. This is for a 3-gen but might apply to 4th gens also:
http://www.cybrrpartspro.com/Chilton...61CH01_43.HTML
Old Jul 1, 2003 | 01:20 PM
Remington's Avatar
Hey Jeff, thanks for the reply. I'm not sure if I should use the DexronIII or not.
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
pktaske
Sep 4, 2015 08:40 AM
