Firewall hole?
Firewall hole?
Hey does anyone know if there is an easy to access hole in the firewall (mid engine) so I can run a foglight wire into the cabin? I did a searh and someone mentioned there being one behind the intake manifold and that there's a plastic/rubber thing I can just pull out. Can anyone clarify this? Any info will be great. Thanks
Mason
Mason
use a grommet - don't just run the wire through a hole in the firewall because it will chafe and could short. There's prolly a grommet already in place that you can poke a tiny hole in the center of and feed the wire through there. That's prevent the wire from chafing and also keep the firewall sealed.
Actually I couldn't find the one in the engine bay so I just went to the driver side fender. Used the grommet but not by poking a hole through it, instead I just lifted it out on one side and slid my wires in and pushed it back since poking a hole large enough was quite difficult. All in all it was a learning experience, thanks for the help guys.
~Mason
~Mason
i drilled thru the fuel line, works good, so good the engine dont even need be running to lose gas, half a tank inside half on the grass, good thing i didnt have much in it, word of advice, check to see if theres a hole pre made inlike my *** who had to buy 3 bottles of fabreeze
fastcarny
10-12-2015 07:06 AM
DC_Juggernaut
09-28-2015 04:07 PM
max ride 41
09-17-2015 06:17 PM
