keyless remote?
Old Feb 1, 2001 | 09:10 AM
Dusky's Avatar
Do the 95 SE's come stock with keyless remote? I have a 95 SE but I do not have the remote and I never have but I have the security system (stock) and in the fuse box their is a fuse for the keyless entry! I want to buy a factory keyless remote but only if my car will be able to use it.
Old Feb 1, 2001 | 09:34 AM
Daniel B. Martin's Avatar
Look for the relay
This response is based on information from the '99 Maxima factory service manual. Perhaps your '95 is wired the same way.
The manual refers to the keyless remote feature as the Multi-Remote Control System. It uses a Multi-Remote Control Relay. Look to see if your car has this relay.
1) Open the trunk. Remove the trunk compartment floor carpet and the fiberboard spare tire cover. These are removed with your hands; no tools are required.
2) Remove the cardboard trunk trim which surrounds the latch mechanism. The five plastic fasteners which secure it are quarter-turn latches and come loose easily when turned with a Phillips head screwdriver.
3) Look at the area of the trunk latch mechanism, made visible by removal of the the trim panel. Locate electrical connector T5. This is a brown plastic connector with 6 terminal positions. If your Maxima does not have the keyless entry feature you will find connector T5 taped up so it does not rattle, but with no relay plugged into it.
4) Reinstall all the trim you removed.
This whole operation should take three minutes.
Old Feb 2, 2001 | 06:24 PM
jlwardn's Avatar
It was part of the SE convienence pack. If you have a power seat you probably should have keyless. Look on ebay...they sell the extra keyless entries there.
ToTheMax305
Sep 23, 2015 09:11 PM
flu2000
Sep 14, 2015 12:34 PM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
