Harlan switch problems
Old Jul 2, 2003 | 10:28 PM
DaThrillr's Avatar
my harlan switch has been working fine for a while now, but then today i was pn the highway and got on the gas and blahhhh nothign activated at 5000 rpm like i had the switch set for usually id feel the extra kick from the VI but nothing so later on i opened the switch up and reset it to # of cylinder, and RPM (2k just for a test).... the switch accepted the setting and i started the car up and blah nothing at 2k ... but it did activate at 2500... i tested different rpms and all had a correction of 500rpm ..... so in order for my VI to activate at 5k i have to set the harlan switch to 5500rpm...
has this happened to anyone else ? if so any way i can fix it? will it get worse?
Old Jul 2, 2003 | 11:52 PM
xHypex's Avatar
The OEM tach is off by a few hundred rpms to begin with, but 500 off is a little more than what I've seen on other cars. Is your Harlan in the engine bay? If so maybe the heat is affecting the values the harlan reads.
-hype
Old Jul 3, 2003 | 01:00 AM
sbslacker's Avatar
I'm starting to think that the Harlan is a piece of junk. So many threads now about problems associated with it. Ugh...
Old Jul 3, 2003 | 06:16 AM
Stephen Max's Avatar
Seems to be a quality control issue. I have a light in my dash that goes on whenever the Harlan activates the MEVI, and it has never failed to activate when I hit 5000 rpm. I just ordered a second one to use as a shift light, I hope it's a good one.
Old Jul 3, 2003 | 07:12 AM
xHypex's Avatar
I currently have 3 Harlans on my '99, and they have worked everytime for over a year now. I did install one on a friends '97 that has flaked out, but one of my Harlans was sent in the same box as his. I'm beginning to think it's less of a defect problem and more of an issue with either a) user installation or b) different model years.
For example, on my car when I hooked the Harlan up to the Rpm lead on the ECU my tach stopped working (went to 0 and stayed). The Harlan worked, but it caused issues on my car for some reason (which has an ECU closer to a 2000). I believe (and always suggest) that the best way to setup the Harlan is from the coil, and many haven't done that so maybe theres more fuel for the fire.
-hype
Old Jul 3, 2003 | 07:49 AM
-hype
Interesting. That's the way I have mine set up.
Old Jul 3, 2003 | 09:36 AM
Bags's Avatar
VG Ridah's Biatch Hoe
-hype
My 1st harlan worked like a champ, bought in may 2002. But it got water in it and died in feb 2003.
The current one I have is flaky. It works sometimes. And I am tapped into the coil.
HOWEVER, I am moving it inside the car today.
I think the heat issue might have some good merit as well as the parts that are on the rpm switch.
I think some of the parts maybe cheaper or older ( + 1 year )than others.
But there IS something to all of this.
I just can't seem to narrow it down to really anything.
Old Jul 3, 2003 | 12:42 PM
JeffesonM's Avatar
living out of a maxima...
I've had the Harlan in my engine bay, wired to the first coil pack for maybe 8 or 9 months now. No problems yet (except irresistible urge to redline car).
Old Jul 3, 2003 | 05:29 PM
DaThrillr's Avatar
sorry i havent got back to u guys .. but my harlan is in the "cockpit" and i am using a relay on the switch... tomorrow im going ot install the LED to the switch so i can see when it activates....
i have my set up to the coil pack also i tried the ecu wire but i got the same results as Hype ..that baffeled me so i just ran it to the coil pack...
i really hope the switch doesnt blow or else i gotta wait another 3 weeks for a new one..
Mar 12, 2020 12:06 AM
rnb754
Sep 14, 2015 11:39 PM
Maxie40
Sep 14, 2015 11:28 AM
