Anyone know what Gear Oil to use?
either will be just fine. where do you live? I just ordered the mt-90 for my 99 I live if Iowa and my temperature range is about -40to100 so occording to my chilton's manual 90 weight is a little better but either will be just fine. Mine should be getting hrere tomorrow.
I live a far 18 miles south of Buch434 and just added Redline TRanny fluid. I used 3 qts MTL and 2 MT90 to balance it out. I went to lunch today & it was 4 outside and the car shoifted like it was 80 like butta...
By the way Buch...take a gander at the comments of the Pacesetter catback thread below-I was curious and asked the members about it. Not all are keen but you just can't beat that price!
PS I'd recommend wd-40 the fill/drain bolt at the fornt of the tranny in advance of the fluid change. I would also try and get this bolt loose before you drain the fluid (Mine was EXTREMELY hard to get off and I bench press over 400 lbs-actually broke my ratchet). The drain bolt should come right off...
What Gear Oil to Use.
Thanks.
Downside is the hassle/small cost (really not much). We live in IA where it is currently about -2 and -35 with windchill. I left my car outside all day and got it and drove it home like it was 80 outside. The cold no longer affects the shifting (although I still let it warm up B$ reving above 2-3000 rpm). Best of all-now I can shift into 1st when just rolling whreas before I had to stop and double clutch or choose 2nd and lug it... I have bout 100k on my car and figured it was a good maintenance item. FOr $45 or so my tranny should remain maintenance free forever.
I know Mobil 1 makes sythetic tranny fluid but it's about the same price as Redline. From the research-both seem excellent with flow at low temps and viscosity maintenance. I used Redline b/c I couldn't find the Mobil 1 in 70-80wt. Remember to lossed the drain/fill plug BEFORE you drain the fluid (learn from my mistake) and that bolt has some stuff on the threads to make sure it doesn't come off. Once that's loose-you're home free!!!
05RLS2
Apr 14, 2016 11:49 AM
