Accessories Belt help
Old Jul 4, 2003 | 09:16 AM
96white's Avatar
Ok, my old belt was all cracked, so I got a new gates belt to replace it. The reason I replaced the old one was that it hisssed all the time.. So I talked to my mechanic and he said I needed a new belt. So now that I have the new belt on it does that Squeel noise for about a second and goes away. What is wrong?
Please help
Old Jul 4, 2003 | 05:09 PM
96white's Avatar
anyone?
Old Jul 4, 2003 | 05:25 PM
gtr_rider's Avatar
192.168.1.1
Is it loose? It shouldnt deflect too much or it would most problem squeek. Make sure.
Old Jul 4, 2003 | 05:28 PM
96white's Avatar
thats what I thought, I had him tighten it yesterday. He said he did, and it still makes the noise? any other suggestions? get another mechanic to look at it?
Old Jul 4, 2003 | 10:21 PM
Dave Holmes's Avatar
Have it tightened some more, just to the point that it doesn't squeal on a cold startup. If tightened too much, it will wear out the bearings in your accessories.
Dave
Old Jul 4, 2003 | 10:38 PM
96white's Avatar
How do i know if its tightened to much?
thanks for your help so far.
Old Jul 6, 2003 | 03:09 AM
Sometimes you'll be able to hear the bearings in the accessories being "strained" (don't know how else to explain it). You should recognize it when you hear it. There will also be very little deflection in the belt. I adjust mine till there is a little squeal, then tighten gradually till there isn't any.
Dave
Old Jul 15, 2003 | 07:56 AM
mtwhite's Avatar
My belt has always squealed when the weather is wet or humid at startup. If I keep it in the garage it is fine. I've been told this is just a trait of serp belts. I used to spray the belt with belt dressing, but if it was wet the belt would squeal with or without the dressing. The only time it does this is first thing in the morning. Sound familiar?
Old Jul 15, 2003 | 08:03 AM
96BLUMAX's Avatar
What do i need to tighten my belts?
markevans999
Oct 25, 2015 08:27 AM
BobTX10
Oct 7, 2015 08:43 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
